Hauppauge DCR-2650 or HVR-2250? - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: 2650 or 2250?
2650 0 0%
2250 0 0%
Voters: 0. You may not vote on this poll
post #1 of 9 Old 07-27-2012, 09:04 PM - Thread Starter
cmorris1441's Avatar
I am looking at getting either the Hauppauge WinTV DCR-2650 (http://www.amazon.com/gp/product/B005FPT38A/ref=oh_details_o00_s00_i00) or the Hauppauge 1229 WinTV-HVR-2250 (http://www.amazon.com/gp/product/B001E2T6Y4/ref=oh_details_o01_s00_i01).
Currently I favor the 2650 external tuner. However, I have Dish Network so I couldn't get an M card for it. Would I still be able to use it as a DVR if I connected it to my Dish Network box? I would have the cable coming from the satellite plugged into the cable in on the Dish Network receiver. Then I would have the coaxial out cable from the satellite plugged into the cable in port on the 2650. The 2650 would then be connected to the computer by USB.
If that doesn't work I will get the 2250. If it does work, then I'm not sure which I should get. I've read a lot about the 2650 having some channels with copy protection limiting recordings to be viewed only on the computer used to make the recording. Is there anyway around this? Also, does the 2250 have these same copy protection limitations?
Thank You.
cmorris1441 is offline
post #2 of 9 Old 07-27-2012, 09:49 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Component out from the STB to a Hauppauge Colosus for Satellite from what I have read.
Sammy2 is offline
post #3 of 9 Old 07-27-2012, 10:06 PM - Thread Starter
So is that the only way I can use this with satellite or does it avoid copy protection? ...or is this your recommendation?
Thanks for the response.
post #4 of 9 Old 07-28-2012, 02:39 AM
signcarver's Avatar
Cablecard tuners don't tune analog or OTA/ATSC, the chip they use is qam only so throw all those out of consideration for satellite (unless you really want to spend a lot of money and convert the component output to clear qam, but you would still need a tuner).
You didn't mention which receiver which might make a difference on controlling tuning as well as outputs available (such as having a TV2, component, composite, hdmi, etc .). If you were really only wanting the coax out of the receiver, nearly any analog tuner would do (including the 2250 you mentioned) but even then I would probably use an svid or composite output if available (also depends on tuner having A/V inputs). I'm also not sure why you are looking at 2 tuner cards in this scenario (I can think of a couple of reasons but from your post I don't think it will work the way you are thinking).
Generally speaking, if you want to build a dvr for satellite, the Colossus or the external HD-PVR are what you should consider. If for some reason your receiver is not HD the colossus might be overkill but the price difference isn't much for other hauppauge cards. I might consider that 2250 but there are many others that would be better/cheaper depending on if you also want to tune analog cable and/or ota at the same time.
signcarver is offline
post #5 of 9 Old 07-28-2012, 07:14 AM - Thread Starter
Here is my dish receiver:
http://www.dbsinstall.com/dish_network/receivers/Dish_Network_ViP211_Receiver.asp
So the 2650 definitely wouldn't work with Satellite as a DVR only? I would still have it hooked up to the receiver, instead of a cableCARD, so wouldn't that decode the stream fine?
I've got a brother with a 2650, I'm going to try and have over this weekend and I'm going to see if I can set that up.
post #6 of 9 Old 07-28-2012, 10:51 AM
Rico66's Avatar
The 2650 is strictly for cable only. As others have said above, for Satellite you can go with the Colossus (internal) or the HD PVR (external/USB), if you want to record/capture in HD.
Rico66 is offline
post #7 of 9 Old 07-28-2012, 11:17 AM - Thread Starter
Reviews on the Collossus don't look great and the PVR is too much. Are there any other brands you could recommend that would work with satellite?
I would like to keep price close to $100, but I could go up to the Collossus' price.
post #8 of 9 Old 07-29-2012, 08:00 AM
stanger89's Avatar
Quoted: 2635 Post(s)
Liked: 1354
For Dish, with that receiver there are only three outputs:
1) Analog SD (coax/composite/s-video)
2) Analog HD (component)
3) Digital HD (HDMI)
Your only options for recording from that box are an analog tuner, then S-Video (SD) is the best quality, or you can record HD via Component or HDMI, and really the Collossus or HD PVR are the best options for that (support/compatibility wise).
cmorris1441 likes this.
stanger89 is offline
post #9 of 9 Old 07-29-2012, 09:35 AM - Thread Starter
I saw the Colossus has a $20 rebate if ordered from Newegg so I ordered it last night.
Reply Home Theater Computers
