data recovery for RAID - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-28-2012, 04:42 AM - Thread Starter
hehe299792458's Avatar
Quoted: 21 Post(s)
In the middle of a rebuilding process, one of the drives in my RAID 6 array decided to break down and take the entire array with it. The drive is encountering multiple SMART errors. Please see pictures. Any ideas on how to remedy it? The drive is a Western Digital RE4-GP 2GB 2002FYPS drive with firmware 04.05G05
hehe299792458 is offline
post #2 of 6 Old 07-31-2012, 02:48 AM - Thread Starter
Quoted: 21 Post(s)
A few more details.... Actually, I still don't have all the information, but I have a much better picture.
Here's my setup:
OS: Windows Server 2008 R2
HDD: Western Digital 2002FYPS
Raid Controller: 3ware 9650SE 24ML
Array: RAID 6 (14 HDDs)
Here are the error logs from my RAID controller.
https://dl.dropbox.com/u/10737837/lsi.Win2k8R2.HOMESERVER.072412.10704.zip
https://dl.dropbox.com/u/10737837/errorlog_0.dat
A few nights ago, the array reported that there was a problem with two of the drives (drives 0 and 5). I'm not sure what the exact error was. I was in the middle of a relatively large transfer (~50GB). All of a sudden, my system froze for about 2 hours, and after that, I managed to do a normal restart. The controller does this sometimes - kicks out two drives randomly and then proceeds to rebuild them.
When the system started, I checked 3DM2 (the raid controller software). It said that the array was degraded and proceeded to automatically rebuild the array. Everything was fine until the rebuild process hit 14%. Then I received several errors concerning drive 3 (which is strange, because the two drives that were dropped are 0 and 5). While the rebuilding process is still listed as "active" under 3DM2, it hasn't progressed at all overnight.
I took drive 3 out of the array and ran the WD diagnostics software on it:
I also tried reading the SMART data via HD Tune:
post #3 of 6 Old 07-31-2012, 04:57 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Here's my setup:
IME the general answer is that you take the array down, take off the existing drives, add the replacement hardware (2 new drives), bring the array back up and mark the replacement drives as hot spares. Then take the array down, add back in the complete old array, reboot and let the controller do its stuff.
arnyk is offline
post #4 of 6 Old 07-31-2012, 06:54 PM
leewcraft's Avatar
If your controller is flagging random drives as failed, I think you probably have a bad RAID controller (or backplane if they attach to a backplane board rather than being cabled directly to the controller). I think you should try either replacing that part or maybe seeing if there's a firmware upgrade available before doing any RAID array reconfiguration. Your array may be fine if the controller is the issue, but you can definitely mess up the array and lose your data if you do the wrong things with adding/removing drives and reconfiguring the array.
leewcraft is offline
post #5 of 6 Old 08-01-2012, 07:55 AM
BizarroTerl's Avatar
Quoted: 38 Post(s)
Liked: 46
This is the main reason I went with Unraid. No matter how bad it gets, you can only lose the data on the drives that are bad.
Leewcraft's advice should be followed. You're in a precarious situation and one wrong step can have severe consequences.
BizarroTerl is offline
post #6 of 6 Old 08-01-2012, 10:09 AM
csmith's Avatar
Quoted: 60 Post(s)
Liked: 29
As Bill Clinton use to say "I feel your pain".
Note leewcraft's post, if your third drive is still available when you boot up your system again, you might be able to finish the re-build before it totally fails. I've never had two drives fail at the same time with my SATA RAID6 system (Areca card), so I don't know if the re-build time is longer if you replace both or just one. The problem with these large size HDs, it takes much longer to re-build if you have 10TB+ in one RAID set, which makes you vulnerable to another failure and loss of the RAID6 when the third drive fails.
Having SCSI drive RAID5 systems with 250GB drives in old days seems like a blessing, also had a lower hard drive failure rate. I won't be going above 12TB in a RAID6, once I found that re-building took 2 days.
csmith is offline
Reply Home Theater Computers
