.mkv or .mp4 to use with IPhone and IPad - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-09-2012, 05:30 AM - Thread Starter
Erighan's Avatar
Quoted: 14 Post(s)
Hey all. Been playing around with Handbrake and need some help before converting my entire library.
For video playback of both sDVD and HD content on Apple (and possibly other branded mobile) devices, what is the better format; MKV or MP4?
I know Apple doesn't natively support MKV, but it seems there may be apps that can provide playback? Is that true? If so, any recommendations?
On a separate note, I tested converting a 720p DVD (about 120min) to see how large a 1:1 rip would be and it came to 1GB. Is that the norm? Can I expect any less without lossing too much quality?
Erighan is offline
post #2 of 7 Old 08-09-2012, 05:39 AM
Arslanx's Avatar
Arslanx is offline
post #3 of 7 Old 08-09-2012, 09:37 AM
JMGNYC's Avatar
I'm not really sure what the advantage is between .mkv and .m4v technically. I'd imagine since they are both containers it depends on what your playback device/software prefers.
I can recommend this if you need to remux from .mkv to Apple compatible .m4v. I use it all the time and it does pretty much everything needed.
http://www.videohelp.com/tools/MkvToMp4
JMGNYC is offline
post #4 of 7 Old 08-09-2012, 10:26 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Originally Posted by Arslanx View Post
AVPlayer is everything you need: http://itunes.apple.com/us/app/avplayer/id395680819?mt=8
This
Mfusick is offline
post #5 of 7 Old 08-09-2012, 04:10 PM - Thread Starter
Erighan's Avatar
Quoted: 14 Post(s)
Originally Posted by Mfusick View Post
This
Perfect. Should I assume that means MKV the better container format?
Erighan is offline
post #6 of 7 Old 08-09-2012, 10:48 PM
whiteboy714's Avatar
For strictly use with apple I would say no. If thats all the videos will be for its probably easier to use the format apple likes natively.
In general mkv is probably the best container as it supports a wide variety of video, audio and subtitles. A lot of stuff that won't really matter on an ipad.
whiteboy714 is offline
post #7 of 7 Old 08-10-2012, 02:07 PM
utee05's Avatar
Quoted: 30 Post(s)
Does AVPlayer work on ipad as well? The app doesn't have the + on it to show that it is compatible with both.
UPDATE: Nevermind there is a AVPlayerHD for the ipad.
utee05 is offline
Reply Home Theater Computers
