Nvidia discrete GPU for MadVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-10-2012, 01:09 PM - Thread Starter
Vlad Theimpaler's Avatar
Liked: 33
Hey all, quick question...
I am looking into a passively cooled solution for HTPC discrete graphics card. Wish to use Nvidia specifically, for MadVR use.
I am presently looking at the following 2 cards. They are similar, and only about $5 difference in price.
1. ASUS ENGT430 DC SL/DI/1GD3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121448
2. ASUS ENGT440 DC SL/DI/1GD3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121469
Here is a comparison of the specs (from Newegg):
*Card comparison*
I can get the latter (the GT440) at Amazon for $66.99 after ASUS $10 rebate, so I am inclined to do that. But I wanted to check with the pros at AVS first smile.gif
TIA
Vlad Theimpaler is offline
post #2 of 4 Old 08-10-2012, 01:26 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
http://www.avsforum.com/t/1361920/cheapest-videocard-for-madvr
I have that first one and it works fine right now but maybe it won't with future versions of MadVR?
Sammy2 is offline
post #3 of 4 Old 08-10-2012, 02:01 PM - Thread Starter
Liked: 33
Thanks. Looks like the second option is out due to space limitations in my HTPC case frown.gif
Looks like I'll need to do more research for other MadVR-viable options that are passive (fanless).
post #4 of 4 Old 10-03-2012, 06:15 AM
Tony_Montana's Avatar
Quoted: 45 Post(s)
if silence is the most important fact , then 7750 is the best solution
if you want only nvidia buy a 650
Tony_Montana is offline
Reply Home Theater Computers
