Is there a way to always output the movie original Resolution and refresh rate? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-13-2012, 11:47 AM - Thread Starter
danbez's Avatar
Quoted: 33 Post(s)
I know that with TMT5 I can use the Auto-Refresh frame rate to output Blu-Ray movies at 24Hz to my TV/Projector. I wonder if there is a solution to change both the resolution and refresh rate based on source.
For example, I would like to have my desktop/WMC set to 1080i by default since this is the resolution used by most of TV broadcasts (USA). When playing a DVD (I use MediaBrowser with TMT and/or WMC player), somehow set the resolution back to 480p, 59Hz and then return back to 1080i once finished. The same for Blu-Rays, using 1080p, 24Hz.
Right now I just leave WMC set to 1080p, but unless I send the original Live TV resolution to the TV (1080i), I see dropped frames here and there which is quite annoying. But of course I don't want to see Blu-rays at 1080i :-)
My Video card is an Asus GT430 (fanless) and my TV is a LG 6700.
danbez is online now
post #2 of 12 Old 08-13-2012, 12:19 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
I know JRiver Media Center does this, but no idea about other software.
fitbrit is offline
post #3 of 12 Old 08-13-2012, 01:47 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
Your tv is an LCD and has a native resolution of 1920x1080p. What this means is that whatever resolution you input, the tv will internally upconvert it to 1920x1080p. It is a waste of time to input these different resolution when in the end, the tv will upconvert the resolution. You need to find a video decoder that works well for tv broadcast so it can deinterlace it properly then you would get progressive video.
Madvr and MPC-HC can change resolutions/refresh rate depending on the video.
Mrkazador is offline
post #4 of 12 Old 08-13-2012, 02:30 PM - Thread Starter
danbez's Avatar
Quoted: 33 Post(s)
Unfortunately it's impossible to use anything else but the WMC default MS encoders for Live TV.
post #5 of 12 Old 08-13-2012, 06:10 PM
walford's Avatar
The de-inteterlaceing logic in todays TVs has come a long way in the last couple of years as has the upscaling algorithims.
As stated above there is no way to display anything but the native resolution on a fixed pixel TV(LCD/LED or Pixel).
Many TVs today also automatically detect film Camera produced video and will then use (Inverse Telecine logic to convert it to 24fps co it can be converted to 1080p/60 withoug suffering any frane rate conversion Judder.
walford is offline
post #6 of 12 Old 08-18-2012, 05:25 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
3:2 and IVTC aren't an issue this side of the pond - but surely you'd want to output 1080/24p content (Blu-ray mainly - though increasingly IPTV streams as well?) as a 1080/24p signal and display it at a multiple of 24Hz refresh to avoid 3:2 judder.
I'd hope that 120/240Hz etc. displays didn't convert 1080/60i 3:2 pull-down removed 24p content to 1080/60p - you'd want them to convert to an n x 24Hz refresh rate surely - to avoid 3:2 cadence judder - wouldn't you? (You'd go 5:5 with 120Hz or 10:10 with 240Hz )
sneals2000 is offline
post #7 of 12 Old 08-18-2012, 05:27 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
But don't the MS H264 decoders offload both H264 decoding and de-interlacing to DXVA - so the quality of the result is dependent on the implementation. (i.e. you can benefit from vector adaptive de-interlacing on higher-end TV cards - which is likely to out-perform quite a lot of HDTV de-interlacing implementations?)
post #8 of 12 Old 08-18-2012, 12:29 PM
whiteboy714's Avatar
I always figured the TVs deinterlacing would be better. Not that I send it 1080i. The i3 550 handles it fine for me.
whiteboy714 is offline
post #9 of 12 Old 08-19-2012, 08:14 AM - Thread Starter
danbez's Avatar
Quoted: 33 Post(s)
Sometimes it is just frame drops here and there. Other times, I get a "film like" output for 1 or 2 seconds when watching video (like the news program).
I will try to disable Aero and see if it happens somehow. If not, my plan is to set the resolution to 1080i (most of broadcasts use it) and let MadVR change it back to 1080p based on content... in this situation, what would happen with DVD content? Would MadVR also change the output to 1080p or leave it to 1080i?
post #10 of 12 Old 08-19-2012, 10:38 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
The 'few seconds of film' effect usually happens on Motion Adaptive or simple Bob/Weave switched de-interlacing when the motion detection hasn't realised the source is native interlaced (aka video) rather than native progressive (aka film) - it shouldn't happen with decent Vector Adaptive de-interlacing.
I don't think there are many decent ways of taking a 1080i signal into windows and keeping it 1080i for output - almost all systems de-interlace to 1080p and re-interlace ISTR. Suspect 480i content would be deinterlaced, scaled to 1080p and then re-interlaced to 1080i (though that may well be better than doing a 240->540 line field scale anyway).
post #11 of 12 Old 08-19-2012, 10:44 PM
Dodgexander's Avatar
Compare the quality manually. Set 480i or p in your graphics card properties. Do you notice improved scaling our deinterlacing with 480 sources?
If you do then it's probably worth using mad vr.otherwise convenience would just be best and leaving 1080i will be fine. As long as you don't watch any progressive content. As then you will go from p to I to p.
Sent from my Blade S using Tapatalk 2
Natalya Simonova: Do you destroy every vehicle you get into?
James Bond: Standard operating procedure. Boys with toys.
Goldeneye
Dodgexander is offline
post #12 of 12 Old 08-19-2012, 10:53 PM - Thread Starter
danbez's Avatar
Quoted: 33 Post(s)
Interesting. The problem is that the NVidia drivers don't allow me to set the de-interlacing mode like the ATI does. Seems to be fully automatic, and I don't have any idea of what trype of de-interlacers the driver is enabled. All I can see is that by setting it to 1080i most of the film like issues disappear. It is also interesting that on an older TV (720P JVC LCD), I don't see any of that. (using the same HTPC).
Reply Home Theater Computers
