Issues with Windows 8 and HD 5670 (Solved) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-13-2012, 09:40 PM - Thread Starter
Joeforsale's Avatar
Installed Windows Professional 8 x64 RTM and CCC will not recognize my display driver which wouldnt be so bad (Win 8 installed its own driver for the HD5670) but I can't scale the image to remove the black bars around my TV. Has anyone resolved this issue before? I've tried using Driver Sweeper, rebooting, uninstalling display driver, and then reinstalling CCC. I'm using the CCC manager installer for Win 8 that AMD has on their site for my card. If someone could shed some light on this for me a would greatly appreciate it.
*Edit* Switching to (after trying many) version 11.1 CCC worked for me, and now all options in CCC are available. Hope this helps someone else out. I also used Windows Uninstall Manager followed by Driver Sweeper to completely remove AMD Display drivers before installing 11.1.
Joeforsale is offline
post #2 of 4 Old 08-14-2012, 09:43 AM - Thread Starter
Joeforsale's Avatar
Just in case anyone cares it looks as though GPU scaling will have to be done through regedit as opposed to using CCC. If I manage to figure it out I will post back on here.
post #3 of 4 Old 08-14-2012, 09:46 AM
assassin's Avatar
Quoted: 87 Post(s)
Liked: 246
Well that's a deal breaker for sure.
assassin is online now
post #4 of 4 Old 08-14-2012, 09:52 AM - Thread Starter
Joeforsale's Avatar
That's how I feel right now, but others have had success using GPU scaling through CCC. Not sure why (other than my bad luck) this is happening for me. It may not be AMDs fault but Im pretty certain I'm going NVIDIA next round. On a positive note my SSD boots much faster (@ 15 seconds) than it did with Win 7.
Reply Home Theater Computers
