MPC-HC 1.6.3.5818 official release - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-14-2012, 04:49 PM - Thread Starter
HDGT's Avatar
http://mpc-hc.sourceforge.net/downloads/
New official release of MPC-HC is out.
HDGT is offline
post #2 of 10 Old 08-14-2012, 04:53 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Changelog
Note
This changelog only applies to current stable build. For complete logs check links below.
1.6.3 - 14 August 2012
•New:
•New webpage (http://mpc-hc.sourceforge.net)
•Source code moved to GitHub (https://github.com/mpc-hc)
•The DirectX runtime dlls are included in the distribution packages so it’s no longer needed to install the DirectX runtime
•MpegSplitter: support for DVD-Audio LPCM and MLP in .aob files
•Use FFmpeg for AC3 and DTS decoding
•If the icon library is modified in a way that can break the icons associated to the extensions handled by MPC-HC, MPC-HC will automatically try to fix the registry so that each extension is associated to the correct icon
•Changed:
•Unrar is statically linked and so MPC-HC and VSFilter no longer need the unrar dll
•The Icon Library was rewritten leading to smaller size
•The Output Options page was redesigned for better usability
•Ticket #625, The translation dll’s size was decreased by 2/3 (uncompressed)
•Ticket #2227, Hide the seek bar in capture mode
•Ticket #2276, Use the new user interface on Vista and later for the Save dialogs
•Ticket #2342, MPC-HC will now use the Windows theme font for the Statusbar, OSD messages and a few other places on Windows Vista and newer
•Ticket #2378, Move the “Remember last playlist” option into the Options dialog
•Updated:
•Unrar to v4.20
•MediaInfoLib to v0.7.59
•ZenLib to v0.4.28
•FFmpeg (git 603221e)
•Little CMS to v2.4 (git eb67549)
•SoundTouch to v1.7.0pre r143
•Armenian, Basque, Belarusian, Catalan, Chinese Simplified and Traditional, Czech, French, German, Japanese, Polish, Russian, Slovak and Ukrainian translations
•Fixed:
•The hand cursor wasn’t shown in the web links in Keys and WebServer options page
•Toolbar code cleanup and background fix for Windows XP
•The last textbox used in the Goto dialog was not remembered since r3964 and r3965
•Always show an error message instead of crashing when the argument of a command line switch is missing
•OggSplitter: Fix crash with some files
•Logitech Keyboard support updated and made optional (Options -> Tweaks)
•WebServer: various bugfixes and improvements
•Ticket #504, Fixed rounding errors that prevented a properly centered image and caused unneeded resizing because the video size was off by one
•Ticket #2330, Fix the radio buttons in the Logo options page
•Ticket #2349, Recent Files: “Clear List” did not remove all files from the list
•Ticket #2356, The “With icons” and “File(s)” options in the Formats options page were not applied if no association was previously modified
•Ticket #2362, [DVB] Fix the Electronic Program Guide (EPG):
•Fix the parsing of the event’s information
•Fix the parsing of the characters’ encoding
•Fix the display of the start and end time when DST is observed
•Ticket #2365, The volume slider wasn’t properly redrawn in some cases
•Ticket #2427, The command line was not parsed when using slave mode
•Ticket #2470, API: Ensure that a 32-bit application can control MPC-HC 64-bit
•Ticket #2493, Fix a crash when saving subtitles using the sub format
•Numerous other bugfixes and improvements
Sammy2 is offline
post #3 of 10 Old 08-14-2012, 04:54 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
The version I have installed from last May is working well for me. I'll let a few other people use it and report back..
Sammy2 is offline
post #4 of 10 Old 08-14-2012, 08:39 PM
ferbal's Avatar
Hi Sammy2
Thanks for the update info.
One question. I open the new MPC version and it asks me if I want to check periodically for update. I say yes but the next time I open the player it asks the same. It's some way to disable this?
Thanks again.
ferbal is offline
post #5 of 10 Old 08-15-2012, 04:14 AM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
View -> Options -> Miscellaneous -> disable update check.
aliaskary77 is offline
post #6 of 10 Old 08-15-2012, 07:23 PM
ferbal's Avatar
Thanks aliaskary77 for your answer.
It's not that. Already tried it. It isn't that the player is telling me that is a new version and asks me if I want to update.
It's that every time I open this version of the MPC-HC there's a pop up message that asks me:
"Do you want to check periodically for MPC-HC updates? This feature can be disabled later from the Miscellaneous options page."
Clicking the "YES" or "NO" button makes no difference.
ferbal is offline
post #7 of 10 Old 08-15-2012, 07:34 PM
Quoted: 46 Post(s)
Liked: 56
only other time i have seen something similar is due to write restrictions. launch mpc as admin, select no. close and open as normal and see if it still asks you. did you use default path for install?
post #8 of 10 Old 08-16-2012, 10:58 AM
ferbal's Avatar
aliaskary77.
I will try this tonite when back home.
I remember now that I was having problems with the mpc-hc.ini file that was changing to default all my settings each time I opened the player, so I changed it´s file attributes to read-only. Thanks. Will check and tell.
ferbal is offline
post #9 of 10 Old 08-16-2012, 08:06 PM
ferbal's Avatar
Enabling writting in the mpc-hc.ini file has solved my problem.
Thanks again aliaskary77.
ferbal is offline
post #10 of 10 Old 08-17-2012, 04:42 AM
Quoted: 46 Post(s)
Liked: 56
sometimes non-default install locations can do that. one of the folders progam files, program files (x86) or program data files is sometimes restricted if not installed with proper access.
i had this issue with bsplayer, and maybe xbmc, cant remember.
Reply Home Theater Computers
