Help me decide between these 3 affordable Routers... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-16-2012, 07:31 PM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
gonzo90017 is offline
post #2 of 6 Old 08-16-2012, 08:11 PM
Bizzy G.L.X.'s Avatar
Hi gonzo,
As the TrendNet and Linksys are pretty close in the important specs (300 mbps, WPA2 and output power), I'd recommend the Linksys, as it's compatible with DD-WRT.
Unfortunatley, the Asus is limited to 150 mbps.
Case:Fractal Design Node 605
APU:AMD Richland A10-6700
RAM:8GB AMD 1866
Board:ASUS A88XM Plus
Storage:OCZ 256 GB Vector
Optical:Panasonic Slim BDR
PS:Silverstone Strider 550 Gold SFF
Software:WMC8+LAV+madVR+MPC-HC
Input:Logitech K400 mini KB/trackpad+Harmony 720
Output:Sammy 55" S6 LED LCD+Yamaha soundbar
Bizzy G.L.X. is offline
post #3 of 6 Old 08-16-2012, 10:36 PM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
Cool. Thanks for the info. Here I thought only the Asus was compatible with DD-WRT. I will go with the Linksys then.
post #4 of 6 Old 08-17-2012, 09:12 AM
ogormask's Avatar
is dd wrt over tomato a preference still or is there news in that area?
ogormask is offline
post #5 of 6 Old 08-17-2012, 07:17 PM
Good question, not sure about Tomato, I've only had the time to flash to, and use DD-WRT...
RAM:8GB AMD 1866
post #6 of 6 Old 08-17-2012, 07:18 PM
Coolio bro, let us know how it's going when you get everything setup !
RAM:8GB AMD 1866
Reply Home Theater Computers
