Can I have two tuner cards in the same computer? - AVS Forum | Home Theater Discussions And Reviews
Old 08-19-2012, 06:57 AM - Thread Starter
Carl_Ballard's Avatar
I currently have a Ceton card for cable. Can I add a tuner card to work off my antenna and have them co-exist? I'm using W7MC with the Ceton card. I'm not sure that W7MC can handle a 2nd tuner card. Or can a capture the 2nd tuner card's files separate from using W7MC?
Carl_Ballard is offline
Old 08-19-2012, 08:05 AM
whiteboy714's Avatar
Yes you can. I have a acetone and a two tuner ota as well. Wmc has a limit of 4 tuners per type. So if you got a second detonation you would need an app called tuner salad.
Sent from my ASUS Transformer Pad TF300T using Tapatalk 2
whiteboy714 is offline
Old 08-19-2012, 12:03 PM - Thread Starter
That's great news. What is the popular ota tuner these days? You lost me with "a second detonation"?
Old 08-20-2012, 05:12 AM
captain_video's Avatar
Quoted: 511 Post(s)
Liked: 336
captain_video is online now
Old 08-20-2012, 06:16 AM
coppertubing's Avatar
coppertubing is offline
Old 08-20-2012, 07:19 AM
Quoted: 511 Post(s)
Liked: 336
Old 08-20-2012, 08:52 AM
Jackal55's Avatar
I have two Avermedia Duets in mine.
Jackal55 is offline
Old 08-20-2012, 06:25 PM - Thread Starter
Okay. Can I assume you guys are yanking me around?
Old 08-20-2012, 06:46 PM
mcturkey's Avatar
Liked: 43
I'm trying to comprehend how autocorrect converted Ceton to both acetone and detonation...
mcturkey is offline
Old 08-20-2012, 07:31 PM
Originally Posted by captain_video View Post
Oh shoot sorry guys. Guess I was half asleep on my tablet didn't even notice that.
Didn't mean to derail the thread. OP if you are looking for a dual tuner. There is basically two main options.
Hauppauge WinTV-HVR-2250
AVerMedia AVerTVHD Duet
I have the duet it has been great in my first gen Intel i3 htpc. But these cards have been known to act funny in certain setups. I originally had it in an Intel 775 setup and the card would often disappear in windows. RMA'd it and it did not help.
But works great in my current htpc. So I have to give that disclaimer when recommending them.
Also reviews for tv tuners are especially bad because a lot of people simply don't understand what the card is capable of.
Old 08-21-2012, 05:59 PM - Thread Starter
Glad we're back on track. I'm going to give the Hauppauge a try. Thanks.
Old 08-22-2012, 09:57 PM
Multimediashtick's Avatar
Quoted: 24 Post(s)
Liked: 42
Whiteboy left out the HDHomerun Dual, though it is not an internal device and network based it is much more versatile and I would bet that software support will be there with W10.
Multimediashtick is offline
Old 08-23-2012, 02:41 PM
Oops my bad your right I always forget about that one for some reason.
Old 08-23-2012, 06:12 PM - Thread Starter
Thanks for another option, but I'm going to try the Hauppauge first.
Old 08-23-2012, 09:14 PM
Jackal55's Avatar
I use SageTV to record my shows and the one problem that I've had is that I had at first was that I had forgotten to scan channels with the other 3 tuners. I did have a problem just recently with the upgrade of the SSD over the weekend but once I upgraded SageTV to version 7 it recognized the cards and all was well. I did a test to day an recorded 4 shows at once with no errors. I'm set for the Fall season.
OP, if you only want two tuners then you would only need one Duet card. I have two so I can record four shows at once if the schedule is stacked like that.
Jackal55 is offline
Old 08-24-2012, 10:27 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If you already have Ceton installed, you don't need tuner salad, since Ceton driver ups the max tuner limit to 32.
I have a Ceton and 4x Magyca Clear QAM tuners.
All you have to do is tell windows which tuner you want to use for which kind of channels.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Old 08-25-2012, 08:53 AM - Thread Starter
Good to know. I'll be doing the setup next weekend.
Old 08-25-2012, 08:54 AM - Thread Starter
On a side note, there used to be a print thread option - has that gone away?
Old 09-02-2012, 03:35 PM - Thread Starter
I got the bare bones Hauppauge 2250 card without all the accessories. However, my IR receiver 1/8" plug will not fit with card's plug hole. Anyone know what size the plug hole is and where I can either get an adapter for my 1/8" plug or an IR receiver with the correct size plug.
Old 09-03-2012, 08:32 AM
gary_johnson_53@'s Avatar
I started with this :
CPU AMD PNENOM 8450 (X3)
Motheboard GIGABYTE GA-MA78GM-S2H AM2+ ATX
Realtek ALC889A codec + High Definition Audio
ATI Radeon 451 3200 graphics card
Hauppauge WinTV-HVR 1800 MCE Kit 1128 PCI-Express x1 Interface
Gigabyte has an x1 and x16 PCIE. First card went into x1
Got this one on ebay (Nationwide Surplus) for 16.49 + free shipping. Its an OEM version of the above with only antennae inputs
Hauppauge WinTV-HVR 1800 PCI-Express x1
But this card into the PCIE x16 slot, windows 7 recognized it and installed the driver.
went into MCE and tasks , setup and reran TV configuration
Tested recording 2 HD shows at once
Works great.
With PCI-E, you can put a x1 into an x4, x8 or x16 slot!
gary_johnson_53@ is offline
