Audio out of sync with multiple players, mouse stuttering with windows 7...advice needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-20-2012, 09:19 AM - Thread Starter
Quoted: 20 Post(s)
I've an Asrock vision HT with windows 7 installed hooked up to a samsung 3d tv. a logitech bluetooth keyboared/mouse combo is what i use for input.
everything was fine until I started trying to install all the HT software using tutorials here.
The sound is no longer in sync with movies in VLC and windows media player as well as some of the other players mentioned on this forum.
I installed codecs recommended here. sharky or something along those lines is the most recent I installed.
the mouse has stuttered for a little while as well.
any suggestions for where to start looking? I'm an OS X user so am learning windows 7 slowly but surely.
nycmtber is online now
post #2 of 2 Old 08-20-2012, 11:26 AM
Selden Ball's Avatar
Quoted: 3068 Post(s)
Liked: 1500
You'll need to be explicit about which software packages and which versions you've installed. Some of the packages are, shall we say, less useful than others.
Edited to add:
You might try doing a reset to a recent restore point. It's a reasonably reliable way to undo recent software installations -- usually doing a better cleanup than running the official deinstallers.
Selden
Selden Ball is online now
Reply Home Theater Computers
