Internet issues. Modem or Switch? - AVS Forum | Home Theater Discussions And Reviews
Old 08-20-2012, 11:12 PM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
A couple of days ago I switched to TimeWarner cable from AT&T. I purchased this modem to avoid having to pay monthly fees.
I have 2 pc's. Bedroom pc, and living room pc. In order to have internet access on both pc's I connected the modem
and both pc's to the switch. The problem is that only 1 of the pcs gets internet access.
The other one complains about not having a valid IP configuration. If I disconnect the one with internet access from the switch,
reboot the modem, then run Network troubleshooter on the one without internet access this same error gets fixed.
But now the original one with internet access complains about not having a valid ip configuration.
This same setup worked fine with AT&T's modem yesterday.
gonzo90017 is offline
Old 08-21-2012, 03:14 AM
acejh1987's Avatar
Do you have a router at all?
With a cable modem you will need a router between the modem and the switch, that way the router will give each PC an unique IP address.
The modem will only work by itself with one PC connected, hence why either PC will work but not at once.
With AT&T you probably had an all in one router/modem thats why it worked fine, where as with cable they are usually separate and the modem does not act as a router.
acejh1987 is offline
Old 08-21-2012, 03:37 AM
lovekeiiy's Avatar
Liked: 30
I agree with the above. You can pick up a good router that'll have four ports for $50 to $100, and will include wireless access.
lovekeiiy is offline
Old 08-21-2012, 09:08 AM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
Thanks I had a feeling it was something like that but figured i'd ask the experts. I Ordered a router on the 16th. Damn Amazon and there slow ass free shipping!
Old 08-21-2012, 10:33 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If one of the PC's always on, you can run router software on it.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Old 08-21-2012, 02:21 PM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
Can you give me more info on how to do this?
Old 08-21-2012, 02:36 PM
Zon2020's Avatar
Seriously, why would you want to mess with that when you can buy a really nice, gigabit-wired plus dual-band multi-antenna wireless router for less than $75?
Sometimes it reaally is better, much easier, and more cost effective, to just buy an appropriate piece of hardware.
Zon2020 is offline
Old 08-22-2012, 11:12 AM
lsilvest's Avatar
Go to NewEgg and look at the Trendnet Routers. I've had great luck with their products and have used one of their routers for a few years with both cable and DSL and never dropped a signal. If you want a free router, go to SamKnows.com and sign up for their broadband study - non-intrusive and you'll never know it's there and you get a very good router.
lsilvest is offline
Old 08-22-2012, 11:34 AM
Zon2020's Avatar
You indicated you had already ordered a router, but if you need one, I suggest reading the thread What is the very best wireless router available right now?
BTW, after that thread (and after sending back a Cisco E4200V2), I am happily using a refurbished Netgear WNDR4000. Fast, great solid connections, not a blip, has never been reset, really easy to configure, and only $75 factory refurbished at Amazon.
Zon2020 is offline
Old 08-22-2012, 11:59 AM
pixelation's Avatar
The best router is one that runs open source software like DD-WRT with USB storage. You can do a ton of things on it. A DD-WRT router with gigabit switch can be bought for as little as $20.
pixelation is offline
Old 08-22-2012, 12:07 PM
Zon2020's Avatar
Not necessarily. Many routers work very well with the proprietary software.
And you can't buy a dual band 450mbps wireless router for anything close to $20. If you're satisfied with a 150mbps 2.4Ghz-only wireless router, then go for it. If you want better performance than the bare minimum, then you'll have to pay more. Open source software isn't going to get you a 5Ghz radio or higher speeds.
Zon2020 is offline
Old 08-22-2012, 01:30 PM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
I ordered a Linksys E1000 from Amazon on the 16th. It supports DD-WRT. I got free shipping so they're taking their sweet time to send it to me. I was just looking for a temporary workaround until it arrives. And looks like I found one. I forgot that I could connect the modem directly to the Ooma (which I left out of my cool drawing for troubleshooting sake), then connect the Ooma into the switch. Now all the pc's connected to the switch can connect to the internet at the same time.
Old 08-22-2012, 02:11 PM
pixelation's Avatar
I have no ideas Ooma can function as router. I have to wonder how could you Ooma work earlier when 1 of your PC is taking over the IP?
Just be aware that now all your unencrypted PC traffic can be seen by Ooma.
http://blogs.computerworld.com/oomas_trojan_horse_strategy_for_the_home
Old 08-22-2012, 02:15 PM
pixelation's Avatar
OP was using a switch. I would assume Wi-Fi is not his top priorities.
Besides, forget 450Mbps. All my devices are perfectly happy with just 54Mbps 802.11g network. I even watch .WTVs in HD over Wi-Fi without any issues.
Old 08-22-2012, 03:24 PM
Zon2020's Avatar
Does he have a smart phone? A tablet? Is there no wireless device in his entire house? No wireless radio or camera, or any other wireless device? If there isn't today, there will be soon.. And as long as one is buying a new router, why not get one that provides good high speed wireless coverage as well as gigabit wired? Of course the answer to that is obvious, which is why there are fewer and fewer wired-only routers being made and sold (many stores don't even sell wired-only routers any more).
And as I said, if you're satisfied with a 150mbps 2.4Ghz-only wireless router, or even worse, with horrific wireless G throughput, then go for it.
But I certainly wouldn't recommend it to anyone else.
Zon2020 is offline
Old 08-23-2012, 12:08 AM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
This is only a temporary solution. With my old AT&T wireless router the switch was connected to slot #1 and Ooma was connected to slot #2.
I never used Ooma as my primary router until now.
Like I said before, this is only a temporary solution. I'm expecting this router (which I ordered on the 16) to arrive tomorrow. Not the best but I was looking for something affordable. When tax season rolls around i'll take a look at some dual bands.
