File Sync - AVS Forum | Home Theater Discussions And Reviews
Old 08-21-2012, 08:53 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Looking for recommendations.
I was thinking of FreeFileSync.
Is it good?
Any other suggested programs?
I used TeraCopy with verify selected to move some files off of a drive I want to format but want to verify / compare the two folders to make sure I didn't miss anything important.
Sammy2 is offline
Old 08-21-2012, 09:48 AM
stanger89's Avatar
Quoted: 2653 Post(s)
Liked: 1355
stanger89 is online now
Old 08-28-2012, 07:06 AM
video321's Avatar
Quoted: 21 Post(s)
Robocopy is my favorite. It can do it all and is already installed if you're using Win7.
video321 is offline
Old 08-28-2012, 07:48 AM
anleva's Avatar
I use FreeFileSync to mirror files from two different drives to another. Works great for me. Good simple application, easy to use. It does have a compare function to determine which files are new/changed.
anleva is offline
Old 08-28-2012, 09:31 AM
perpetual98's Avatar
Quoted: 69 Post(s)
Liked: 46
I think Microsoft has an application called Sync Toy that I've been using lately to mirror a couple drives. At least that's what I think it's call. No frills, but seems to do the job.
perpetual98 is offline
Old 08-28-2012, 09:36 AM
acejh1987's Avatar
I also use FreeFileSync to compare and make a mirror backup to an external drive, never had any problems.
acejh1987 is online now
Old 08-28-2012, 04:23 PM
kesawi's Avatar
Quoted: 30 Post(s)
Liked: 25
+1 It is a very powerful tool. The following command will verify whether the files in the source folder will match the destination folder:
robocopy source destination /mir /l
The /mir switch makes a mirror copy of the source directory in the destination directory and deletes any files that don't match the source. Using the /l switch makes it do a test run only and doesn't write or delete any files. You'll need to execute it at the command prompt. At the end it will display a summary showing how many files will be copies/modified changed. If it is zero then you have an exact copy. If not, drop the /l switch and it will add the missing files.
kesawi is offline
Old 08-28-2012, 07:10 PM
ymarker's Avatar
Quoted: 27 Post(s)
I like windows live mesh. Can specify what and where to sync. Can also sync to cloud if desired
ymarker is offline
