DVD watching -- media center or media player ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-21-2012, 02:08 PM - Thread Starter
ralphcramdon's Avatar
Win7 home edition --
If you're IN media center, if you put in a DVD, it will bring up "play DVD" and there you go.
But if media center isn't running and you put in a DVD, it will bring up media player. (a bit redundant if you ask me).
So, really which gives the best viewing experience for DVD's and why? (or VLC also for that matter).
ralphcramdon is offline
post #2 of 8 Old 08-21-2012, 03:49 PM
Karl Beem's Avatar
Quoted: 16 Post(s)
ZoomPlayer.
Karl Beem is offline
post #3 of 8 Old 08-22-2012, 12:51 PM - Thread Starter
yeah? and why?
but still trying to learn about differences between watching dvd's in media center compared to player (or does media center actually use MP as the application but you don't know it?)
been watching inside media center and happy with it but just curious.
i'm betting there one in the same -- media center perhaps a slimmer version of mp?
post #4 of 8 Old 08-22-2012, 01:15 PM
jrwalte's Avatar
By default they're using the same set of media foundation codecs, so yes, they're the same. If you want an inserted disc to load WMC instead, go into the auto play settings under control panel and change it to WMC. There can be exceptions, once you start installing additional codecs or running 32-bit MP instead of 64-bit (for instance, you can install 64-bit codecs that impact x64 WMC and MP but the x86 MP will still use the original 32-bit media foundation codecs).
jrwalte is offline
post #5 of 8 Old 08-25-2012, 03:00 PM - Thread Starter
Thanks jrwalte -- figured as much.
Now I just heard media center isn't even a part of Win 8 ! ?
I love microsoft but that's typical.
post #6 of 8 Old 08-29-2012, 01:15 PM
vision-master's Avatar
Liked: 24
Ok, now comes the problem (region free usage).
vision-master is offline
post #7 of 8 Old 08-29-2012, 08:36 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Plenty of region free players out there. MPC-HC and VLC for two.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #8 of 8 Old 08-30-2012, 07:20 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
It depends on your environment.
If I was sitting at a desk I wouldn't want to wait and load WMC and then cycle through to the movie library. I'd rather just use WMP.
Now I sit eight feet away and have WMC locked and open full screen all the time on my tv. No reason to use WMP.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Reply Home Theater Computers
