Logitech remote issues - AVS Forum | Home Theater Discussions And Reviews
Old 08-26-2012, 12:44 PM - Thread Starter
jefejt's Avatar
I reprogrammed the my logitech remote so that the number keys acted as a directional mouse. It worked great for a while, but now the curser will only move a little bit at a time. I used to be able to hold the key and it would move until I let go. Any suggestions as to why and how to get it to work correctly? The other issue is the volume. If I hit the volume button up or down it moves three units at one time. I'd prefer it to only move one. Any suggestions?
THanks.
jefejt is offline
Old 08-26-2012, 05:05 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
Sounds like something in your IR system has changed. Are you pointing at the item straight or through an IR engine/repeater system? Besides, if you programmed it once before, just wipe it and start over - or just resync to the logitech site!
Andrew Hornfeck is offline
Old 08-26-2012, 09:04 PM - Thread Starter
jefejt's Avatar
I just have the remote and a IR receiver. No repeater. I tried reprogramming the remote, but I have the same issue.
jefejt is offline
Old 08-27-2012, 07:10 AM
lockdown571's Avatar
Quoted: 37 Post(s)
Liked: 87
If you go through the troubleshooting dialog in the Harmony PC program, isn't there an option that says something like "device responds too many times or not enough to remote presses". Then it will allow you to change the repeat number on button presses.
lockdown571 is offline
Old 08-27-2012, 07:19 AM
lovekeiiy's Avatar
Liked: 30
tried wiping off IR lens on both the remote and PC.
I would also suggest changing the batteries.
May not help, but couldn't hut either.
lovekeiiy is offline
