Media Center Stopped Working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-27-2012, 02:30 AM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
That’s the message I got while watching an OTA recording. I checked for an online solution and wrote down the names of 3 filepaths. They were all in a temp folder but when I went to look for them they were not there, & I do have things set to view hidden files.
Here’s a screen print I was able to grab. I tried to capture the lower portion but the rest of the TV screen was black & there was no access to any other app so I could grab only one screen print.
Anyone ever see anything like this?
Mike99 is offline
post #2 of 4 Old 08-27-2012, 07:01 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Once in a great while this happens to me. Usually scheduling or doing a manual re-boot helps with this sort of stuff. Win7 is the most stable version of Windows yet but re-booting helps keep things running smoothly.
Sammy2 is offline
post #3 of 4 Old 08-27-2012, 11:07 AM - Thread Starter
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I think I just re-booted the day before. WMC restarted & I played the recording without a problem.
I've had problems with Comcast DVRs, Dish DVRs & Panasonic DVDRs. I guess why should HTPC be any different.frown.gif
Mike99 is offline
post #4 of 4 Old 08-27-2012, 12:44 PM
Vlad Theimpaler's Avatar
Liked: 33
@Sammy2...
If you don't mind, could you please divulge the versions of Media Browser, MPC-HC, and MadVR that you currently use? And also the nVidia driver revision you have for your 430GT card? I hope you don't mind this query, but I am building a HTPC with similar specs as yours, and am planning to install the same software you use (7MC + MB + MPC-HC + MadVR) for media browsing and playback.
Infrequent crashing of 7MC is something I hope to avoid, but I can live with it if in return I get great browsing and playback features + performance from this setup. I am cautiously optimistic on this one smile.gif
TIA
Vlad Theimpaler is offline
Reply Home Theater Computers
