Old HTPC question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-27-2012, 03:54 PM - Thread Starter
jefejt's Avatar
I gave my old HTPC to my sister. It's an AMD Athlon 64 X2 6400 3.2gHz on a ASUS M3N78-EM motherboard with HDMI out. It has 4 GB of RAM. It's using a HD Homerun as a tuner. She says she's getting bad pixelation from the HD NBC channel as well as one of the HD PBS channels. I didn't really have issues other than occasional pixelation, but hers is pretty bad. Would a dedicated video card help? What other possible solutions might there be?
jefejt is offline
post #2 of 8 Old 08-27-2012, 04:06 PM
Zon2020's Avatar
What is she using as a source? An OTA antenna?
Maybe she just isn't getting a very good signal and need to re-orient or replace her antenna?
Zon2020 is offline
post #3 of 8 Old 08-27-2012, 04:43 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
I agree,
Low signal strength.
Andy_Steb is offline
post #4 of 8 Old 08-27-2012, 05:27 PM - Thread Starter
jefejt's Avatar
Actually its a QAM cable signal. They work fine on other tvs in the house.
jefejt is offline
post #5 of 8 Old 08-28-2012, 08:16 PM - Thread Starter
jefejt's Avatar
It isnt antenna. Any suggestions?
jefejt is offline
post #6 of 8 Old 08-28-2012, 08:43 PM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
Is she hardwired or wireless. If wireless that is almost certainly the problem. If hardwired, might still be the network. Could still be the signal even if its cable... installing a quality drop amp (or having the cable co do it) usually helps.
DanPackMan is offline
post #7 of 8 Old 08-28-2012, 09:11 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
But be sure to check the signal levels from one of the many tools provided by SiliconDust before you waste your time or money on an amp. The network based one will tell you the actual level or the Config GUI gives you a red to green scale (yellow being acceptable),
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #8 of 8 Old 09-05-2012, 01:59 PM
kakron21's Avatar
Yeah, I would definitely run the tools that come with the card. Biggest issue is if there's an extra faulty splitter between her and the rest of your coax network, low or high signal can cause issues.
kakron21 is offline
Reply Home Theater Computers
