Files with DTS-HD MA 7.1 show up as 5.1? - AVS Forum | Home Theater Discussions And Reviews
Old 08-27-2012, 03:56 PM - Thread Starter
Venturai's Avatar
Is there a known issue where files containing DTS-HD Master Audio 7.1 only show up as 5.1? A couple of my Blu-ray mkv rips, most notably The Avengers and Thor (among others), are showing up as 5.1 and only 6 channels. It's only something I realised when I noticed that Transformers 3, which instead uses Dolby TrueHD, shows up as 7.1 in XBMC but my others do not.
I use Makemkv to rip and am definitely selecting the DTS-HD MA track. Since I typically bitstream to my receiver, I can be pretty sure I'm getting 7.1, right? I have the Onkyo NR1007 avr, and I'm not sure if the display changes when its receiving 7.1 over 5.1, but I'll check that again tonight.
Venturai is offline
Old 08-27-2012, 04:09 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
Ripped Avengers w/ MakeMKV and my Pioneer receiver showed 7.1 DTS HD MA.
almostinsane is offline
Old 08-27-2012, 05:19 PM - Thread Starter
Venturai's Avatar
Thanks mate I'll check mine again tonight while playing. I was just wondering if it's a known issue or something. It's a bit misleading scrolling through the list in XBMC or checking file properties in Potplayer/MPC-HC because you don't know what's really 5.1 and what's 7.1.
Venturai is offline
Old 08-28-2012, 04:24 AM
cheeky chappie's Avatar
Go you mean the GUI interface reports the files as being 5.1? or that you only get 5.1 when you playback the files?
If just the GUI reporting then I'll think you find this is down to the programs using ffmeg to provide the media info, since ffmeg can't decode DTS-MA files I think it only reports 5.1 from the DTS core track. The reported number of channels for TrueHD is fine because ffmeg can decode that.
cheeky chappie is offline
Old 08-28-2012, 06:56 AM - Thread Starter
Venturai's Avatar
I read that somewhere about ffmpeg, yeah. They need to update that.
It is the only problem though, because playing back my Avengers rip tonight, I could see the surround back speaker graphics lit up on the avr's display where they weren't with 5.1 material. It had me a little concerned to be honest, either that my ripping program was doing it wrong, or that I figured I'd only be getting 5.1 because that's all my computer thought was present.
I must admit, I wasn't getting a lot from the back channels while watching The Avengers though. I'm thinking about bumping them up a few dBs to be honest, just to help give them some emphasis because they're so easily drowned out by the fronts and sides.
Venturai is offline
