Next generation atom will be quad core - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-30-2012, 06:34 AM - Thread Starter
jeffkro's Avatar
Reading the specs for the next generation atom and I'm thinking it will probably handle HD streaming which is the main thing zacate and current atoms can't do. Anyways looks like there is potential for a completely passively cooled, super low energy, HTPC.
http://www.dailytech.com/article.aspx?newsid=25547
jeffkro is offline
post #2 of 10 Old 08-30-2012, 07:01 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Let's hope it's better than CedarTrail. I was psyched for the D2700 and I did use it in a few builds but not HTPC -- a couple of audio server and office PC builds. The biggest fiasco with CedarTrail was the GPU driver support. Horrible. It's like they just gave up.
StardogChampion is offline
post #3 of 10 Old 08-30-2012, 10:54 AM - Thread Starter
jeffkro's Avatar
The next generation zacate is suppose to be quad core also so it should handle HD netflix and have decent drivers, the only thing is that I don't think it will be nearly as efficient as a 22nm intel part. But yeah, if MS and AMD worked together to support silverlight in hardware acceleration even the current generation zacate would run HD netflix just fine. fairly frustrating.
jeffkro is offline
post #4 of 10 Old 08-30-2012, 11:49 AM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
The GPU: Atom meets Ivy Bridge
Recent Atom processors have opted to use graphics processors licensed from PowerVR, the same company responsible for the GPUs in iOS devices and other smartphones and tablets. But Valleyview brings things back in-house: it will offer a seventh generation Intel-made GPU with four execution units.
In plain English, this is the same graphics technology used in Ivy Bridge's HD 4000 and HD 2500 GPUs, though those parts have more execution units—16 in the HD 4000 and just six in the HD 2500. The GPU should support the same APIs as the Ivy Bridge graphics parts: that means DirectX 11, OpenGL 4.0, and OpenCL 1.1 should all be present.
With Valleyview's GPU, you'll get all the media-related features of a modern GPU—Valleyview's GPU can decode H.264, MPEG1, MPEG2, MPEG 4, and VC1/WMV9 video and encode H.264 and MPEG2, and an included VXD392 coprocessor can also decode H.264, JPEG, and VP8, but the reduced number of execution units means you're not going to get staggering 3D performance in desktop games.
What you do get is a GPU that can decode a 1080p stream at 60 frames per second while using just five percent of the CPU's power, which will be very useful for video playback—the GPU also supports Intel's Wireless Display technology to enable AirPlay or Miracast-like streaming to a TV from mobile devices. The GPU's two display pipes support up to two simultaneous displays at once over HDMI, DisplayPort, DSI (for the tablet versions), and VGA (for the desktop and mobile versions).
Indeed. Might make a decent HTPC.
assassin is offline
post #5 of 10 Old 08-30-2012, 12:42 PM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
I get confused when it says the GPU has hardware accelerated encoding.
Does that mean for use when compressing a video file using Handbrake?
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #6 of 10 Old 08-30-2012, 02:21 PM
LexInVA's Avatar
Quoted: 634 Post(s)
Liked: 259
Handbrake does not support Intel's QuickSync at this time. QuickSync is almost entirely used by commercial transcoding programs though I think there are two or three free ones that can utilize it.
LexInVA is offline
post #7 of 10 Old 08-31-2012, 05:38 AM
Quoted: 650 Post(s)
Liked: 432
Ok so I am understanding it correctly in general though - that if your software and hardware both support accelerated encoding that some of the process is offloaded to the GPU to speed it up?
post #8 of 10 Old 08-31-2012, 12:24 PM
LexInVA's Avatar
Quoted: 634 Post(s)
Liked: 259
They have an actual hardware encoder built into the GPU. Dedicated silicon specifically for a few codecs. AMD, Intel, and Nvidia all now have hardware encoders in their latest GPUs instead of the last generation CPU/GPU accelerated processes.
LexInVA is offline
post #9 of 10 Old 08-31-2012, 12:34 PM
Zon2020's Avatar
Although today, cpu-based transcoding using Handbrake may still be superior to any software available that uses GPU-based transcoding. See
The wretched state of GPU transcoding
Zon2020 is offline
post #10 of 10 Old 08-31-2012, 01:01 PM
olyteddy's Avatar
Quoted: 531 Post(s)
Liked: 931
But those commercial programs aren't necessarily very expensive...http://mirillis.com/en/products/splashexport.html
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Home Theater Computers
