Need help choosing a video card? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-31-2012, 06:27 AM - Thread Starter
-89-'s Avatar
My ATI 4800 card is starting to fail me and I think I want to switch to Nvidia (maybe?). It's been a while since I bought this card, so I like to think I can get something way better now.
$100-$175 price range
Need it to carry both 1080p video & Dolby digital audio to my Onkyk receiver via HDMI
3 monitor support might be cool, but not necessarily 'needed'.
I use this computer big time with XBMC and use my Panasonic plasma as a second monitor to use XBMC on.
quote:
HP Pavilion p6210f
AMD Athlon II X4 620 Processor 2.60 GHz
6 GBs of Ram
Windows 7 64 bit
Upgraded to 500w fan
Any suggestions? I want zero problems with playing 1080P HD movies. The ATI 4800 isn't always smooth sailing.
I've been looking at this possibly? ATI Radeon 6870? I hear it has great grades on HD video.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150521
-89- is offline
post #2 of 6 Old 08-31-2012, 07:06 AM
Postmoderndesign's Avatar
Quoted: 238 Post(s)
Liked: 90
I think you will be amazed by how much better current graphics cards have become.
With Nvidia you can offload video from your cpu to the gpu using CUVID and MPC-HC.
$100 is enough to budget for a graphics card unless you are a gamer and then you may need a new motherboard and processor as well. Over $100 you are in gaming graphics card territory.
Madshi has indicated that new capabilities being rolled out in MPC-HC can utilize the newest Nvidia cards so this is a transition period. Waiting may bring more clarity.
I use an Asus GT 440, 1 GB DDR5 and have been very satisfied since installing last year in my 2009 intel core duo computer. I particularly liked not having to deal with ATi catalyst problems.
Many people are satisfied with the lower cost GT 430.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #3 of 6 Old 08-31-2012, 07:07 AM
assassin's Avatar
Quoted: 95 Post(s)
Liked: 247
What?!? To some on here that statement is blasphemy!
assassin is online now
post #4 of 6 Old 08-31-2012, 07:14 AM - Thread Starter
-89-'s Avatar
So, you're saying this here should be great?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121426
That will work with my HP p6210f?
-89- is offline
post #5 of 6 Old 08-31-2012, 07:16 AM
Quoted: 238 Post(s)
Liked: 90
Guess I'll be kicked out of the AVS church. I did not know there was a rigid othodoxy and I need to forget and ignore the constant catalyst problem I suffered through.
post #6 of 6 Old 08-31-2012, 07:26 AM
Quoted: 238 Post(s)
Liked: 90
-89- that is the graphics card I have.
My computer is a 2009 intel core duo with a gigabyte EP45-UD3P motherboard. I have a monitor and plasma attached to the card. Windows 7 is not perfect with two displays and i would have resevations about trying 3 displays.
I bitstream my audio to a Pioneer HDMI 1.3 AVR.
I am not a computer guru. I would imagine your computer will support the 440 as long as you have a compatible motherboard PCI-e slot. Check your motherboard and the card specifications.
Reply Home Theater Computers
