FileBot - The ultimate TV Renamer and Subtitle Downloader - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 08-31-2012, 10:41 AM - Thread Starter
rednoah's Avatar
FileBot is the ultimate TV Renamer and Subtitle Downloader. It just works. Easy.
FileBot is really smart about matching your episodes with online episode info from sources like TVRage, AniDB, TheTVDB or movie info from OpenSubtitles and TheMovieDB. The naming format and folder structure FileBot will apply to rename your media files is extremely powerful and customizable but at the same time really quite simple.
Fetching subtitles has never been easier neither. FileBot will automatically lookup subs from various sources and intelligently match them to your media files. Just drag your files in and FileBot will do the rest.
The GUI is extremely efficient, it's all just a matter of 2-3 drags/clicks. But if you're the really lazy kind, you can automate just about anything using the fully-featured cmdline interface.
Trying to set up a fully automated media center? Extract archives, organize tv shows and movies, download subtitles, fetch artwork and metadata, update XBMC – with µTorrent and FileBot it's that easy!
Official website, forums and downloads:
http://filebot.sourceforge.net/
More info, screenshots and video demo:
Check it out!~
rednoah is offline
post #2 of 16 Old 11-01-2012, 10:28 AM - Thread Starter
rednoah's Avatar
FileBot 3.1
This release brings lots improvements for especially for fully-automated processing, improved series lookup and episode matching especially for ambiguous cases. Other enhancements include better support for renaming of movie folders (rather than files), OMDb/IMDb bindings for naming expressions, ed2k support in SFV panel, and storing rename-metadata in extended attributes (if supported by the platform and filesystem).
Features:
+ Use Link-Drop modifier to drop folders into 'Original Files' allow processing of movie folders
+ Enhanced TheTVDB series lookup (combine online search with local index)
+ Improved episode matching (same-name-different series problem, specials)
+ Use OMDb data (unofficial IMDb API) for the {imdb} binding
+ Set File Creation Date to episode/movie airdate/year on rename if supported by the platform
+ Store rename data as user-defined filesystem attributes if supported by the platform (EAs, xattr, etc)
+ Support ed2k hash algorithm in SFV panel
+ Set -Dunixfs=true via cmdline option -unixfs
Changes / Fixed Issues:
* Various adjustments for Mac
* Fixed various 32/64-bit msi installer issues
* Many other bugfixes and adjustments
Scripts:
* utorrent-postprocess works better than ever!
rednoah is offline
post #3 of 16 Old 11-16-2012, 11:25 PM - Thread Starter
rednoah's Avatar
Have you looked into my collection of useful FileBot scripts yet? If you're using filebot from cmdline, on a headless machine or just for automated downloading & processing, light-weight artwork fetcher, etc these scripts might be of interest:
Script Index:
You can use these out of the box, or modify them to your needs, or build something different entirely in which case I'd like to hear from you. wink.gif
rednoah is offline
post #4 of 16 Old 11-17-2012, 09:42 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I'm assuming OP designed it ?
Mfusick is offline
post #5 of 16 Old 11-17-2012, 07:42 PM
cdru's Avatar
Quoted: 20 Post(s)
Names match so probably a safe presumption.
Java based. Blech.
cdru is offline
post #6 of 16 Old 11-18-2012, 12:26 AM - Thread Starter
rednoah's Avatar
Yep, there's loads of people that looking for exactly that kinda tool, but since coding is fun and marketing is not, I didn't really both in the past. :P
If you don't like it, don't use it, others are quite happy with it though:
https://sourceforge.net/projects/filebot/reviews/#reviews-n-ratings
rednoah is offline
post #7 of 16 Old 11-18-2012, 03:42 PM
rdb4133's Avatar
I have been happy with it. Thanks for a great app! :-)
rdb4133 is offline
post #8 of 16 Old 11-19-2012, 08:07 PM
sidefx79's Avatar
I've been a happy Filebot user for quite some time, so yeah thanks for it! Any chance of a chocolatey.org package for it though? smile.gif
sidefx79 is offline
post #9 of 16 Old 11-22-2012, 08:41 PM - Thread Starter
rednoah's Avatar
Yes
http://chocolatey.org/packages/filebot/
sidefx79 likes this.
rednoah is offline
post #10 of 16 Old 11-27-2012, 01:22 PM
sidefx79's Avatar
Originally Posted by rednoah View Post
Yes
Nice one, thanks! Very useful for downloading and keeping up to date on windows smile.gif
sidefx79 is offline
post #11 of 16 Old 11-27-2012, 10:07 PM
Crisishf's Avatar
I have been using it for the past 6 months or so. It is an amazing app that has saved me tons of time! Thank you very much.
Crisishf is offline
post #12 of 16 Old 12-14-2012, 11:57 AM - Thread Starter
rednoah's Avatar
FileBot 3.2 Get it here!
This release brings lots of tweaks for episode/movie auto-detection and fully automated processing. The IMDb scraper is fixed and http connections will connect through the system proxy by default. Drag-n-drop on Linux now handles GVFS URIs as well and maps them to the ~/.gvfs filesystem abstraction via libgio.
Features:
* Much more robust and reliable movie detection
* Improved movie/series detection and auto-selection
* Transliteration-aware candidate ranking (e.g. 你好 VS ni hao => 100% match)
* New and improved IMDb scraper
* Support drag-n-drop from GVFS locations via ~/.gvfs filesystem abstraction
* Use the system proxy by default
* Replace -clear option with 2 options -clear-cache and -clear-prefs
* {d} binding for movie release date or episode airdate
* {es} convenience binding for multi-episode numbers
* Make the revert function more obvious via a new button
* Fixed various GTK LaF issues
Chocolatey Windows Package available:
Install and keep up to update via "cinst filebot" => http://chocolatey.org/packages/filebot/
Noteworthy Scripts:
New: Revert Renamed Files to their Original Names
Revert files to their original names using the internal history.
=> http://filebot.sourceforge.net/forums/viewtopic.php?f=4&t=5#p2485
New: MyEpisodes.com Integration
Automatically add shows and tick episodes on your MyEpisodes account.
=> http://filebot.sourceforge.net/forums/viewtopic.php?f=4&p=2629#p2629
Update: µTorrent Integration
* Automatically tick new episodes as 'aquired' on MyEpisodes
* Video Tutorial for standalone cmdline usage
* ut_state_allow condition to better support running on state change
* Aupport passing in formats via cmdline
=> http://filebot.sourceforge.net/forums/viewtopic.php?f=4&t=215&p=1561#p1561
Merry Xmas everyone!~
rednoah is offline
post #13 of 16 Old 01-18-2013, 06:27 AM - Thread Starter
rednoah's Avatar
FileBot 3.3 Get it here!
This release brings a brand new Music Mode using AcoustID. There's also lots of enhancements in movie, episode and subtitle processing as well as various scraper fixes.
Features:
* New Music Mode using AcoustID audio-fingerprints and MusicBrainz info
* Support movie detection via tt1234567 patterns in the filename
* Improved handling 1e01 and 101 and S01E01-E02 SxE patterns
* Improved Subtitle<->Episode matching
* Fix Subscene and IMDb scraper issues
* Value of {s00e00} now uses the S01E01-E02 pattern for multi episodes
* Value of {imdbid} now includes the tt prefix
* Added {tmdbid} binding
* Added .m2ts as video extension
* More caching to reduce load on the various webservices
* Automatically process music
rednoah is offline
post #14 of 16 Old 02-12-2013, 04:05 AM - Thread Starter
rednoah's Avatar
FileBot 3.4 Get it here!
This release improves upon the new Music mode, includes lots of adjustments that make automatic matching of episodes/subtitles even better. The GUI will now allow you to rename valid entries despite one or more conflicting entries in the batch.
Features:
* New music bindings: {n} {y} {t} {d} {pi} {pn}
* Allow renaming despite conflicting entries as far as possible
* Improved episode matching esp. for generic patterns
* Improved subtitle auto-matching
* Clear cache via Ctrl+Shift+Delete
* Formatting can now access rename context, added bindings {i} index, {di} duplicate index
* Better samples for the format expression testing environment
* Detect IMDbID from .url files
* No more DBUS warnings on headless machines
* Limit cache to 2 days to avoid episode mismatches caused by outdated episode lists
* enforce well-formed and nicely formatted xml in .nfo files
* only download missing artwork by default
* create .url files
* PushOver notifications
rednoah is offline
post #15 of 16 Old 08-08-2013, 08:45 AM - Thread Starter
rednoah's Avatar
FileBot 3.62 is out! Get it here!
This update brings lots of improvements for movie and episode detection as well as better subtitle auto-selection.
Changes:
* Improved movie / episode detection
* Improved subtitle auto-selection
* New bindings for multi-stream info, e.g. {videos} {audios} {texts}
* AMC: Fine-tune series/movie auto-detection
* AMC: Support in movie.nfo creation
rednoah is offline
post #16 of 16 Old 08-08-2013, 10:50 AM
mud sloth's Avatar
I'd just like to give you a big thanks for this tool! It's really simplified my whole process for downloading stuff. I stumbled through a few possible automating apps before I finally found FileBot and nothing compares. Keep up the great work!
mud sloth is offline
Reply Home Theater Computers
