Fastest and most reliable powerline kit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-01-2012, 11:43 AM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
I currently have a couple of older Netgear powerline devices. At the time they were supposed to be pretty good. It's able to keep up with my network webcam. I need to get one for one of my SageTV extenders; so, ideally, I'd like it something that can comfortably stream bluray discs and/or original bluray bitrate ISOs; with enough headroom for for sending commands without significant lag. I'm guessing a solid, reliable real-world 100mbit/sec would be more than enough. After googling various products; it looks like the current theoretical maximum bandwidth is rated at 500mbps. Im just curious which product works the best at a real-world 100mbps. My home is relatively new; with pretty good wiring; however, it's a 2800sq foot house with two floors.
MKANET is offline
post #2 of 8 Old 09-01-2012, 09:56 PM
jeffkro's Avatar
I think success or failure depends more on the wiring in your house than the powerline kit. I do need to break out my power line adapters I'm running one leg wireless that would be better with power line.
jeffkro is offline
post #3 of 8 Old 09-02-2012, 09:00 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
Obviously the best solution would be a hardwired network. If you have a basement in your 2-story house then the main issue is finding a way to run wiring from the basement to the attic. You can drop cables from the attic to any 2nd floor room. From the basement, you can go up through the ceiling for the 1st floor. The trick is to find a way to run wires between floors.
I have the exact same scenario in my house and I was able to create a raceway between the basement and the return duct for the A/C system that was basically an empty space behind a wall on the 2nd floor. I just cut an access panel from my master bedroom into the return duct area and was able to find a spot that allowed me to drop wires from the 2nd floor to the basement ceiling, although I had to drill a few holes in the floor and ceiling. Once I had a clear path I widened the openings and dropped a long cord through the raceway with plenty of slack which I then tied off at both ends. I just pulled the slack through from the other end, attached my cable, and pulled it up through the wall to the 2nd floor. From there I could easily feed it into the attic and then route it to whichever room required it. I located the frame above the wall and drilled a hole through the 2x4 between studs and dropped the wire through the hole. I cut an opening in the wall where the wire was dropped, installed a low-voltage outlet box (basically just a plastic frame that clamps to the drywall, available at any home supply store), and attached the cable to a wall plate. I connected the cable to a network switch/hub in the basement which also connected to my router for internet connectivity.
Note that if you have a finished drywall ceiling in the basement you will probably have to create an access panel in the ceiling to allow access to the location where the wiring drops from the 2nd floor. I have a drop ceiling in my finished basement that I put in with the knowledge that I'd need to have access to wiring in the ceiling. If you don't have a return duct or other vacant space behind a wall on the 2nd floor a closet will work equally well. You'll probably want to set up some sort of conduit between the closet floor and ceiling to protect the wiring.
captain_video is offline
post #4 of 8 Old 09-02-2012, 10:41 AM
ljo000's Avatar
There are only a couple of standards that the manufacturers produce devices for. The most common are the various HomePlug standards. If you go with 200Mbps HomePlug AV you should be good as long as there's not an issue with the home's wiring. There's a good deal on at newegg for TRENDnet TPL-306E2K Compact Powerline AV Adapter Kit (200Mbps) - $50 for the pair when using promo code EMCNBGN78. That's even cheaper than the monoprice pair with equivalent specs. Keep in mind that the advertised speed is the max you can get. Real-life speeds are a lot lower so you'll want to spend the extra $$ to get 200-500Mbps.
Give it a try and if it doesn't work, think about pulling some cable. Its not hard to terminate Cat5e and patching drywall is cheap and easy.
ljo000 is offline
post #5 of 8 Old 09-02-2012, 12:11 PM - Thread Starter
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
Thanks I really appreciate all the time you guys took to reply. But, I was actually hoping for someone who knew the best suited model/brand that is known to generally work well at streaming sustained high bandwidth non-dynamic bitrate video/audio (>40mbps). ...which is significantly different than the requirements for people who just transfer/copy files or even "HD" internet streaming
(which is dynamic). Having said that, Im just looking for the the highest recommended device that seems to work best generally under those conditions.
MKANET is offline
post #6 of 8 Old 09-02-2012, 09:02 PM
ljo000's Avatar
The problem with that question is that its impossible to answer as it depends on so many factors specific to your house. In general, barring any wiring issues, the 200-500Mbps units should be fine for streaming BluRay quality video and uncompressed audio. However, unlike ethernet over Cat5e/Cat6 powerline is much more subject to interference, surges etc. Your best bet is to buy something from a store with a good returns policy and hope for the best.
ljo000 is offline
post #7 of 8 Old 09-02-2012, 10:24 PM
ajamils's Avatar
Interesting question OP. This is something that I am really interested as well and would like to get some suggestion as well.
[color=Blue]
psn id: hunter4life
Live Gamertag: huntre4life (notice "re" not "er" in hunter)
ajamils is offline
post #8 of 8 Old 09-02-2012, 10:39 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Yep. This is the same thing I tell my friends. Or I let them borrow on I have left over and try it out.
assassin is offline
Reply Home Theater Computers
