What is the least intrusive method to find Windows 7 product key? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-03-2012, 11:49 AM - Thread Starter
pixelation's Avatar
I have 2 installations of Windows 7 using 2 copies of Windows 7 upgrade. I need to reinstall one of them with SSD but I am not sure which one is used on which. I have the product key labels on both of my install disks' package. Is there a way to tell which product key is used on which PC without installing any software?
pixelation is offline
post #2 of 13 Old 09-03-2012, 12:35 PM
erickotz's Avatar
Liked: 30
http://www.magicaljellybean.com/keyfinder/
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #3 of 13 Old 09-03-2012, 12:50 PM
billdacat's Avatar
Quoted: 17 Post(s)
BeLarc Advisor will also do the trick. I will also give you a nice listing of installed software and patches.
http://www.belarc.com/
billdacat is offline
post #4 of 13 Old 09-03-2012, 07:26 PM - Thread Starter
pixelation's Avatar
Thanks. But as mentioned earlier, I need a way to find out the product key without installing software. Any takers?
post #5 of 13 Old 09-03-2012, 07:51 PM
jim2100's Avatar
Liked: 34
Why?
jim2100 is offline
post #6 of 13 Old 09-03-2012, 10:47 PM - Thread Starter
pixelation's Avatar
Because I don't trust keyfinders.
post #7 of 13 Old 09-03-2012, 10:56 PM
jim2100's Avatar
Liked: 34
Well, erickotz already gave you your answer.
jim2100 is offline
post #8 of 13 Old 09-03-2012, 11:12 PM
DeanM's Avatar
You could just try one. If it doesn't activate, try the other.
But I've used Magic Jelly Bean before and it seemed to work fine.
DeanM is offline
post #9 of 13 Old 09-04-2012, 08:48 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Why not just do install an image of your current HDD to your SSD?
Sammy2 is offline
post #10 of 13 Old 09-04-2012, 09:02 AM
signcarver's Avatar
I've used belarc for a decade or so... I'd check them out... I would be a little more mistrusting of the "magicjellybean" one ... not to say its bad but from your response of mistrusting keyfinders, you seem to have had issues in the past with game key finders that are full of malware. Finding the windows/office keys are generally not the same thing.
signcarver is offline
post #11 of 13 Old 09-04-2012, 10:10 AM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
if you dont trust it, finish up backing everything you need and settings etc, then disconnect internet, install, run and get the key info you want. rebuild after formatting. simple!
even it wanted to, it couldnt transmit any data back.
aliaskary77 is offline
post #12 of 13 Old 09-04-2012, 10:40 AM
erickotz's Avatar
Liked: 30
I've used the magical jelly bean one, and it was without issue, but it's probably been ~5 years, so I can't speak to the current version.
erickotz is offline
post #13 of 13 Old 09-04-2012, 12:41 PM
rcrach's Avatar
Nirsoft ProduKey is good. it pulls the OS key and any other keys, like Office that are on your machine. if you've got time to run an uninstalled key extractor, you've got time to run this and then uninstall it.
http://www.nirsoft.net/utils/product_cd_key_viewer.html
rcrach is offline
Reply Home Theater Computers
