HTPC advise - AVS Forum | Home Theater Discussions And Reviews
Old 09-03-2012, 04:00 PM - Thread Starter
jjgear's Avatar
I currently have an AMD BE-2400 and wondering if its worth it or advised that i replace it. Currently just using the intergrated graphics but i am considering getting a radeon 5450. But didn't want to put money towards a card if i should replace the CPU. Really interested in the AMD llano series. Thanks in advance.
JJ
jjgear is offline
Old 09-04-2012, 05:20 AM - Thread Starter
jjgear's Avatar
Forget to put that my motherboard has an integrated Radeon hd3300.
JJ
jjgear is offline
Old 09-05-2012, 07:51 PM - Thread Starter
jjgear's Avatar
Nobody has any input?
jjgear is offline
Old 09-05-2012, 08:13 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Why do you want to change your htpc? Do you want it to do something it can't in its current form?
audit13 is offline
Old 09-05-2012, 08:14 PM
cshaw88's Avatar
For HTPC use I don't think you will see much benefit, if any, from a processor upgrade. Adding an SSD right now is the best bang for your buck. After that adding the 5450 would be my 2nd choice.
cshaw88 is offline
Old 09-06-2012, 01:13 AM
pkarmouche's Avatar
If your current HTPC has a shortcoming, list it here and someone can maybe help you.
An i3 (21xx) on a z68 motherboard + 8GB of ram will handle everything a customary HTPC needs to do... and all can be found for less than $250. (presuming you have a case, PSU, HDD and optical drive already).
I can also attest that adding an SSD (for your primary/boot drive, get a good synchronous drive over lots of GB) will provide the most noticeable performance improvement.
Paul
pkarmouche is offline
Old 09-06-2012, 06:21 AM
mgftp's Avatar
Paul
8GB? I thought an HTPC would never use over 4? ... or are you just saying for the small price difference you may as well get the extra unneeded 8?
mgftp is offline
Old 09-06-2012, 07:21 PM - Thread Starter
jjgear's Avatar
Correct me if i'm wrong. I just got a new Pioneer vsx-1121k receiver and without the upgraded video card i wouldn't be able to HD audio. I am hoping that is correct. That and i didn't know how much an upgrade a new llano would be. Just thought it would be money well spent towards a new cpu and mb if it was a big upgrade. Also my motherboard is restricted to ddr2 1066 and that is lot more money than the new stuff.
jjgear is offline
