Hook up one PC to multiple displays/rooms - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-05-2012, 03:43 PM - Thread Starter
hbarsquared's Avatar
I have a nice gaming PC that I use quite a bit. But, it's in the bedroom, and I'd like to play games on my Plasma TV in the living room, and eventually a projector in the basement. My house is fairly old, so pulling wires will be a pain. Obviously, I'll have to pull wires for this to work at any acceptable resolution and latency, but I want to make sure I have a good plan and the right standards before I pull anything.
My PC has HDMI out, but the cable would be greater than 50', so I don't know if that format would work. I've read about HDMI over CAT5 - has anyone here tried that successfully? Also, input is obviously a factor - I was thinking running a USB hub with a bluetooth dongle attached (so bluetooth -> USB hub -> long cable -> computer), what kind of input latency would that introduce?
hbarsquared is offline
post #2 of 7 Old 09-05-2012, 06:17 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
You might want to post to the HTPC forum about this.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #3 of 7 Old 09-06-2012, 10:58 AM - Thread Starter
Done, will post the link once the new thread is approved.
post #4 of 7 Old 09-11-2012, 03:08 PM
MarkcusD's Avatar
Quoted: 49 Post(s)
Liked: 45
Was just pricing 40ft hdmi cables today. I hope this will work.
psn: markcusd
X1: MarkcusD
MarkcusD is offline
post #5 of 7 Old 09-19-2012, 02:25 AM
w1retap's Avatar
Quoted: 52 Post(s)
Liked: 51
w1retap is offline
post #6 of 7 Old 09-19-2012, 09:38 AM - Thread Starter
Thanks for the links. I've seen wall-mounted faceplates that do the conversion (plug in HDMI, run cat6 off the back) too. Ideally, I want a faceplate that does HDMI->cat6, USB->cat6, and ethernet all in one unit. Wishful thinking?
post #7 of 7 Old 09-21-2012, 11:32 PM
PubFiction's Avatar
Quoted: 17 Post(s)
Liked: 36
I cant say if such a device exists.
But what I can say is the wire runs are usually the hardest part so if you are unsure run what ever you think you might want all at once. When ever I pull cat6 cable I pull at least 2, I am running a similar 30 foot run and I am going to pull 3 ethernet, USB, and HDMI all together and I am thinking hard about running display port too. If you do not future proof, then run a string to 2 alongside the cable so that if you ever want to run another item it will be easy to tie up and pull through.
PubFiction is offline
Reply Home Theater Computers
