Basic question: HTPC Output to AMP says that it is set to 60 Hz. Is this correct, and expected? - AVS Forum | Home Theater Discussions And Reviews
Old 09-06-2012, 07:56 AM - Thread Starter
busb0y's Avatar
I recently bought a new 120Hz TV and I was looking at the output settings in Windows 7 (display/screen resolution/advanced/monitor) it notes the name of my amp and says that it is set to 60 Hz. Should i force this to 120 Hz, or is this expected?
busb0y is offline
Old 09-06-2012, 08:02 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
120hz is how many times per second the tv refreshes its signal, which will most likely be 60hz or 24hz, or some decimal number extremely close to either of those.
It cannot accept a 120hz signal.
If you hit the info or display button on your tv's remote you will see something like 1080p60 or if you are watching a bluray movie 1080p24. That is correct.
You will never see 1080p120
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Old 09-06-2012, 08:05 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
This will depend on the frame-rate of the source file and what your HDTV supports. Could be 24fps, or 30fps or varients thereof. It could even be 50fps or 25fps.
Sammy2 is offline
Old 09-06-2012, 08:56 AM - Thread Starter
busb0y's Avatar
Thanks everyone. It was a silly question but it did make me pause for a moment smile.gif
busb0y is offline
