HTPC build for BluRay MKV streams - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-06-2012, 12:49 PM - Thread Starter
jaboki's Avatar
Currently I have these spare parts on hand:
Harddrive: Crucial M4 64GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441
Memory: CORSAIR Vengeance 4GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820233195
Motherboard: ASRock Z77E-ITX http://www.newegg.com/Product/Product.aspx?Item=N82E16813157312
I'm looking to purchase these parts:
Case: Wesena ITX6 http://www.shop.perfecthometheater.com/HTPC-ITX6-Black-Mini-HTPC-aluminum-chassis-HTPC-ITX6-B.htm
CPU: i3-2125 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115093
Power Supply: picoPSU-150-XT + 150W Adapter Power Kit http://www.mini-box.com/picoPSU-150-XT-150W-Adapter-Power-Kit
Will this be strong enough to stream BluRay x264 content via LAN? If not, does anyone have suggestions as to what low profile GPU will work with this setup? It'll be on Windows/Linux+XBMS streaming from my FreeNAS server.
jaboki is offline
post #2 of 6 Old 09-06-2012, 06:12 PM - Thread Starter
jaboki's Avatar
$10 paypal gift to whoever can answer this question before I order, and it works as intended.
jaboki is offline
post #3 of 6 Old 09-06-2012, 06:17 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Yes, it will.
Sammy2 is offline
post #4 of 6 Old 09-06-2012, 06:28 PM - Thread Starter
jaboki's Avatar
Originally Posted by Sammy2 View Post
Yes, it will.
No stream lag at all?
jaboki is offline
post #5 of 6 Old 09-06-2012, 07:10 PM
Mean KaNean's Avatar
You should have no streaming issues with that at all if you're connecting to the LAN via a hard wired connection.
Mean KaNean is offline
post #6 of 6 Old 09-06-2012, 07:16 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Use my hardware guide. No lag.
assassin is online now
Reply Home Theater Computers
