That's easy a microtik - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-07-2012, 01:28 PM - Thread Starter
akschu's Avatar
The best wireless router out right now has got to be the mikrotik routerboard.
It's not dead simple like the netgear, linksys, dlink (all junk), but you can do whatever you want with it.
You buy this board:
http://www.roc-noc.com/mikrotik/routerboard/rb433ah-complete.html
And at whatever radios you want using mini pci cards.
So if you want 802.11b/g or 802.11n on 5.8, or even at the same time no problem. You can add a third radio to use as a wifi client if you want a directional antenna for an uplink interface to another radio.
In the firmware you can do anything with the firewall, it does radius, hotspot gateway, proxy, qos, mpls, several different routing protocols, ipsec, pppoe (client and server), pptp, and a bunch of other stuff.
From the radio perspective you can change anything including output power.
It even supports packet sniffing to wireshark and nice debugging tools.
The cli supports a scripting language that allows you to control anything including the beep.
So if you want it to beep whenever something associates, no problem.
Nothing else I've seen comes close.
schu
akschu is offline
post #2 of 2 Old 09-07-2012, 04:09 PM - Thread Starter
akschu's Avatar
Sorry about that, I meant to reply to the best wifi router thread, but when I click on reply it just loads the homepage in a sub-window. It could be because I'm using chrome on linux. Hard to say without digging, and I don't have the time.
akschu is offline
Reply Home Theater Computers
