Bluray 3D playback question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-08-2012, 05:51 PM - Thread Starter
nekromantik09's Avatar
Hi guys,
I just got a new 3D TV (LG 42LM6700) and have played back some 3D movies using my PS3 fine, they look awesome and the 3D effects are good and get pop out effects on movies that have them.
However I have one or two region locked discs that I need to play back on my PC using Power DVD 12/11 or TMT5 using i5 2500k and Nvidia Geforce GTX 460 GPU.
Last disc I tried was Final Destination 5 and on my PS3 it works flawlessly but on my PC the background of the 3D image is blurry and the subtitles are doubled just like if you was not wearing the polarized glasses.
I do see depth in the picture but all of the pop out effects are missing and there is a slight blur to the image. I have tried both PowerDVD and TMT and same problem on both, got latest video card drivers, using a mini HDMI to HDMI 1.4 cable and got Nvidia 3D settings enabled in the control panel.
Any ideas?
nekromantik09 is offline
post #2 of 7 Old 09-09-2012, 03:47 PM
wraslor's Avatar
Could be the eye sync needs to be flipped? sometimes it defaults to left eye first and needs to be right eye first or vice versa?
wraslor is offline
post #3 of 7 Old 09-09-2012, 04:31 PM
ricabullah's Avatar
Check whether your eye-wear is working or not, using nVidia control panel.
Chronical Tester
ricabullah is offline
post #4 of 7 Old 09-10-2012, 01:26 PM - Thread Starter
What do you mean eye wear? If you mean glasses then Im using passive glasses.
Yes I have tried swapping left and right with no difference.
I am quite surprised that my PC which is quite powerful cannot playback 3D Blu-Ray on the same level as a PS3.
post #5 of 7 Old 09-13-2012, 02:19 PM
Roussi's Avatar
Quoted: 45 Post(s)
Liked: 36
Sounds to me like you are having two overlapping 3d modes (e.g. the pc is sending 3d interleaved, but the tv recognizes it as 2d, and turns on the 3d simulation) - check that both in the player and on the tv the 3d modes are set to Auto (hdmi1.4), and make sure the sim3d (or whatever it's called) on the tv is turned off.
Roussi is online now
post #6 of 7 Old 09-13-2012, 03:20 PM - Thread Starter
I dont think thats the issue as my TV wont simulate 3D unless you tell it to.
If it gets a 3D signal then it auto switches onto 3D mode while when you feed it a 2D signal it will be in 2D until you select 3D and then choose 2D to 3D mode.
When Im sending a 3D signal using powerdvd it does not let you select a 3D mode its either on or off while with 2D conversion there are different settings.
post #7 of 7 Old 09-14-2012, 01:15 PM
sharangad's Avatar
I had a similar problem. Disabling AnyDVD HD resolved the issue. It has an option to disable 3D and render it as 2D. Disabling the option makes no difference, it still disables 3D.
Unfortunately if you disable AnyDVD HD you lose region free playback.
sharangad is offline
Reply Home Theater Computers
