Flickering video issue. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-08-2012, 10:09 PM - Thread Starter
acuriousman's Avatar
Hello!
I've been seeing flickering video in Media Player Classic. It happens fairly frequently and occurs with Windows Media Player as well.
I've used both the latest build of Media Player Classic Home Cinema and the 1.60 version but the problem persists.
I also tried turning on "deinterlace" in the shaders but it didn't help.
Any ideas?
acuriousman is offline
post #2 of 12 Old 09-09-2012, 09:58 AM - Thread Starter
Anything?
post #3 of 12 Old 09-09-2012, 10:27 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
What content are you playing?
What is it's frame rate?
Sammy2 is offline
post #4 of 12 Old 09-09-2012, 11:34 AM - Thread Starter
This happens with all content, but usually TV shows at 30 fps.
post #5 of 12 Old 09-09-2012, 11:45 AM
tootal2's Avatar
Quoted: 33 Post(s)
I have that problem to but the newest nvidia beta driver seems to fix it.
tootal2 is offline
post #6 of 12 Old 09-09-2012, 12:46 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Hit 411 then INFO on your remote. Scroll to the last page and take a look at what frame rate it is reporting. Maybe this is the 29/59 bug.
Sammy2 is offline
post #7 of 12 Old 09-09-2012, 09:28 PM - Thread Starter
I don't have my remote yet. What can I do in the meantime?
post #8 of 12 Old 09-09-2012, 11:31 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
If using a keyboard press 1, 1, 1, Ctrl+d.
Mike99 is offline
post #9 of 12 Old 09-10-2012, 09:05 AM - Thread Starter
That didn't work in Media Player Classic.
post #10 of 12 Old 09-10-2012, 10:40 AM - Thread Starter
Just confirmed, it's happening with Windows Media player as well.
I should mention, I have the CCCP codec pack.
post #11 of 12 Old 09-10-2012, 12:47 PM
drtdiver's Avatar
Is dynamic contrast turned on by chance? Its in nvidia control panel. Intel calls it by another name for Intel HD graphics.
Sent from my Nexus S 4G using Tapatalk 2
drtdiver is offline
post #12 of 12 Old 09-10-2012, 05:00 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
Sorry, my mistake. With MPC-HC you use ctrl+j.
From my limited experience, MPC-HC did show frame rate irregularities. But WMC7 using the 4-1-1-ctrl-d was more specific. For me it displayed 59.401 but when a stutter occurred it jumped to 29.97 at exactly that point in time. This was with some OTA SD recordings.
That being said, I never saw the stuttering with MPC-HC. And I don't recall playing the same recordings with WMPlayer. But it was obvious when using WMC7.
I just installed an inexpensive HD 6450 video card with its latest drivers & that took care of the problem. Of course YMMV.
Mike99 is offline
Reply Home Theater Computers
