HDCP not passing through? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-09-2012, 08:18 AM - Thread Starter
AnthonyB's Avatar
Ok, this is a weird one...
I tried to watch my htpc yesterday passing through my new avr and it said it wasn't hdcp compatible.
I am kinda concerned by this because I was going to make the step into cablecard and don't have any idea what is going on.
8800 gts dvi to hdmi receiver with hdcp compatibility
Auzentech x-meridian (g1) for sp/dif pass through via pcm
TV is a mits wd65733..
I am guessing it's a problem that I am passing the audio through a different source and that is what is causing the hdcp error.
What should I do? New video card that passes thru audio?
Anthony
AnthonyB is offline
post #2 of 5 Old 09-09-2012, 08:30 AM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Since you're passing lossy audio, I wouldn't think that would cause an HDCP issue. What happens if you by-pass the avr?
audit13 is offline
post #3 of 5 Old 09-09-2012, 09:14 AM - Thread Starter
AnthonyB's Avatar
It does fine..
So, my guess is that it's time to upgrade the video card. Will a gt430 do me well?
Sent from my DROID RAZR using Tapatalk
AnthonyB is offline
post #4 of 5 Old 09-09-2012, 12:24 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
If you're going to upgrade the video card, I would bypass the sound card and feed bitstream HD audio to your avr for decoding. You can't get lossless lpcm over optical or coax. You need hdmi with a protected audio path to get lossless lpcm or to bistream TrueHD and DTS-HD MA.
audit13 is offline
post #5 of 5 Old 09-09-2012, 05:14 PM - Thread Starter
AnthonyB's Avatar
Ya, my x-meridian's days are sadly numbered.. It's been a great card but I guess that comes with the territory.
I guess I'll put it on Ebay soon..
AnthonyB is offline
Reply Home Theater Computers
