MPC-HC prioritized audio. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-16-2012, 07:04 PM - Thread Starter
Harlans's Avatar
Hello,
I just recently installed MPC-HC and followed the Advanced MPC-HC Setup Guide but am having some trouble. Whenever I play a video with MPC-HC, it switches the audio stream (To one of the external audio renders I assume) and I can only hear MPC-HC, Any other program such as Skype, Foobar, or my internet browser do not function with audio until I close MPC-HC. I would like to know what settings I must change to have it play without singling out the stream. Sorry if this has been posted elsewhere, I failed to locate anything with the search function.Regards
Harlans is offline
post #2 of 5 Old 09-17-2012, 08:22 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
I had the same problem with WMC: http://www.silicondust.com/forum/viewtopic.php?p=77443#77443 Here is where the button is:
Harlans likes this.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #3 of 5 Old 09-17-2012, 12:15 PM - Thread Starter
Harlans's Avatar
Thanks for the reply, Other applications can run with sound now but MPC-HC shows a pop up "Audio device is in use" and has no sound. Suggestions? Thanks
Harlans is offline
post #4 of 5 Old 09-17-2012, 09:27 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Sorry, I don't have MPC-HC installed on this machine yet so I don't know.
post #5 of 5 Old 09-18-2012, 09:57 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
I installed MPC-HC last night and it works through the mixer just fine. Perhaps you've changed one of the defaults in it? There is a 'restore defaults' that may help. If not look around in Audio Options for a possible solution.
Reply Home Theater Computers
