Adding remote buttons - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-16-2012, 08:34 PM - Thread Starter
jefejt's Avatar
I'm using a Harmony 600 to control my PC. Is there a way to create an XBMC button? I want to be able to still use one button to open WMC and another to access XBMC. I also wouldn't mind a last channel option. I find it odd that isn't a default choice in the logitech menu.
jefejt is offline
post #2 of 7 Old 09-16-2012, 08:44 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
You can put XBMC in the first position on the taskbar and than map it to the Win +1 command on the remote.
Sammy2 is offline
post #3 of 7 Old 09-17-2012, 06:38 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Some dongle drivers also have hotkeys that you can assign to shortcuts.
And as Sammy2 told me a while back, Select/OK works as Last Channel in WMC. Not sure about XBMC.
mdavej is online now
post #4 of 7 Old 09-17-2012, 08:21 PM - Thread Starter
jefejt's Avatar
Sorry, but I'm not sure exactly what this means...
jefejt is offline
post #5 of 7 Old 09-17-2012, 08:22 PM - Thread Starter
jefejt's Avatar
The select/ok maps as last channel in WMC?
jefejt is offline
post #6 of 7 Old 09-17-2012, 09:21 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Right click the XBMC icon on the desktop or in the program list under the Start button. Select "Pin to Taskbar". When it is on the taskbar, left click and hold, then drag it all the way to the left next to the Start button.
In the Logitech remote set up software, map a key to be Win +1 on the remote. That key will load XBMC when clicked on the remote.
Sammy2 is offline
post #7 of 7 Old 09-17-2012, 09:23 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Yes. For some odd reason, MS decided to make the OK/Enter key the last channel key.
Sammy2 is offline
Reply Home Theater Computers
