Is there a tool to edit tuner selection and tuner priority for a large number of channels from multiple sources? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-17-2012, 01:02 PM - Thread Starter
kentschwartz's Avatar
I'm looking for the best tool to edit the tuner selection and priority for the following without having to edit each channel separately from within WMC7
I am running Windows Media Center 7 with the following tuners:
HDHomeRuns for OTA ATSC channels (6 tuners)
HDHomeRun Prime with Verizon FIOS CableCard (3 tuners)
Pinnacle PCTV USB stick (801e) for FM radio and analog closed-circuit (CCTV) channels.
Hauppauge HD-PVR connected to a DirecTV HR20 box.
I want to edit my channel guide so that:
All local channels are recorded only from the HDHomeRun ATSC Tuners, never from the HD-PVR or PCTV
All premium channels are recorded only from the HDHomeRun Prime CableCard Tuners, never from the HD-PVR or PCTV
All CCTV channels (10 total) are only recorded from the Pinacle PCTV - no need for program guide info
The Hauppauge HD-PVR is only used when I manually capture something
I've downloaded Guide Tool, but don't know how to get it to do what I want. Is there a better tool to meet my needs?
Thanks in advance for any help you can provide.
kentschwartz is offline
post #2 of 3 Old 09-17-2012, 02:23 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Andy_Steb is offline
post #3 of 3 Old 09-18-2012, 03:04 PM
jrwalte's Avatar
Maybe it was just luck for me, but when I merged my clearQAM channels to the CC channel number, WMC automatically set the 2 clearQAM tuners before the CC tuners. You don't have to worry about non-clearQAM channels being assigned to your HDHomerun's, because WMC knows that only the Prime can be used. I suspect the same will be true with your CCTV channels (it will know only the Pinacle supports it). The complexity in your setup will probably be the HD-PVR and it may cause some conflicts.
jrwalte is offline
Reply Home Theater Computers
