Finished my I5 Gaming build but it wont see my creative sound card. I tried 3 slots! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-20-2012, 11:37 AM - Thread Starter
ogormask's Avatar
GIGABYTE GA-Z77-D3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
I dont get it. it doesnt show up. its lit up in the back so its connected right. I tried 3 slots. Am I missing something here? its a creative http://us.store.creative.com/Creative-Sound-Blaster-XFi-Titanium-HD/M/B0041OUA38.htm
Its not listed in device manager. I even disabled onboard audio. im lost.
ogormask is offline
post #2 of 3 Old 09-20-2012, 12:59 PM
jrwalte's Avatar
Can you connect the sound card to another computer? While the mb could be having a conflict or all pci-e slots are shot, the more likely answer is the sound card isn't working.
Do you have another device you can connect to verify the mb slots are good?
Sent from my SPH-D700 using Tapatalk 2
jrwalte is offline
post #3 of 3 Old 09-21-2012, 07:07 PM
Smitty2k1's Avatar
Did you install the drivers?
Smitty2k1 is offline
Reply Home Theater Computers
