Finally built my HTPC/gaming hybrid.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-22-2012, 06:06 PM - Thread Starter
Favelle's Avatar
For years, I have kept my HTPC and my gaming computers seperate. I was recently running an Athlon x3 455 and a Radeon 6450 for my HTPC. I decided that I wanted to game a little on the projector setup (Skyrim, Torchlight, Guild Wars), although I will keep the uber gaming rig for FPS and hardcore PC gaming.
HTPC parts arrived yesterday, assembled, constructed, installed, done!
All the boxes, awaiting the unpacking!
The nMedia 6000B. Its a badass case, no question.
MSI mATX 1155 motherboard (Sandy Bridge). Sooooo tiny. Funny, because it has 4 DIMMS, whereas AMD mATX boards usually have only 2. Still, only using 2 anyways (2x4GB).
Why did I bother getting such a huge case? LOL!
CoolerMaster Extreme 475 in place. A SUPER quiet power supply...more than enough for a 7770, a 128GB SSD, and a single spinning 500GB HD (5400rpm).
Everything in, room to spare, power to spare...just need to finish the cable management.
In terms of LFE, size does matter!
Favelle is offline
post #2 of 13 Old 09-22-2012, 06:19 PM - Thread Starter
Favelle's Avatar
Step 2 of the process was getting a proper lapboard. I avoid controllers like the plague (for obvious reasons), but I needed a viable KB/M solution. It turned out exactly as I had hoped, and only took about 40 minutes!
All the wood cut, edges bevelled, sanded with 80, then 120, then 220 sandpaper:
One coat of stain (black walnut):
3 coats of stain, glued together, and pinned wit screws for extra strength!
I purposely went with a steeper angle than the traditional lapboards, I just felt more comfortable and it gave me more mouse clearance.
All clear-coasted and smooth as silk:
Favelle is offline
post #3 of 13 Old 09-22-2012, 06:20 PM
jeffkro's Avatar
Its a good idea to hold motherboards from the edges, static charge and all that.
What cpu and graphics card?
jeffkro is offline
post #4 of 13 Old 09-22-2012, 07:56 PM
Tiddles88's Avatar
Liked: 24
Never liked the basic Coolermaster PSU's. Old internals and unreliable. A Corsair CX 430v2 would have been better. Still good choices more or less overall. And yes, what CPU and GPU?
Tiddles88 is offline
post #5 of 13 Old 09-22-2012, 07:57 PM
galileo2000's Avatar
..and what HSF?
Good time to buy computers and computer parts: NEVER
galileo2000 is offline
post #6 of 13 Old 09-22-2012, 08:15 PM - Thread Starter
Favelle's Avatar
Radeon 7770 for GPU and Intel G860 for the CPU.
Favelle is offline
post #7 of 13 Old 09-22-2012, 08:16 PM - Thread Starter
Favelle's Avatar
Originally Posted by galileo2000 View Post
..and what HSF?
Stock for now....no OC'ing, temps are 23C in a 19C room idle and 42C under 100% load. I am a stickler for CPU cooling in my gaming PC, but I am adverse to throwing money away for no reason. Stock......for now.
Favelle is offline
post #8 of 13 Old 09-22-2012, 08:55 PM
Tiddles88's Avatar
Liked: 24
A Celeron 540 would have saved a bit more along with an H61 board. The top spec Penitums are rather redundant, so to speak. I hope you have an SSD in there too.
post #9 of 13 Old 09-22-2012, 11:24 PM
jeffkro's Avatar
Na, he's good with what he got for gaming.
jeffkro is offline
post #10 of 13 Old 09-23-2012, 02:56 AM - Thread Starter
Favelle's Avatar
Yeah, my previous Athlon x3 was fine as well, but I wanted to git up some gaming with this new build (hence the new build in the first place). A G630 would have been the LOWEST CPU I would have possibly entertained.
SSD is a Crucial M4 128GB. On the only SATA-6 port on the MB. Works like money. Crystal marks right where it should be.
Favelle is offline
post #11 of 13 Old 09-23-2012, 02:58 AM - Thread Starter
Favelle's Avatar
Exactly. My previous HTPC was just fine as it was. I wanted to add gaming without making another gaming rig like my main machine. This is the perfect balance. And when the Radeon 8xxx series comes out and i5's drop to $100, I can make it even more powerful with two simple drop-ins. Easy peasy.
Favelle is offline
post #12 of 13 Old 09-23-2012, 06:08 AM
Ruiner's Avatar
Skyrim may choke on that dual. You're fine for the rest.
Ruiner is offline
post #13 of 13 Old 09-23-2012, 12:38 PM - Thread Starter
Favelle's Avatar
Seems fine so far. I turned off AA and AF, most everything is on the highest settings. I don't really go under 30fps, so its pretty smooth right now:
Favelle is offline
Reply Home Theater Computers
