Question for the guys with HUGE Blu Ray collections - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 10-02-2012, 01:19 PM
jrwalte's Avatar
Originally Posted by ncarty97 View Post
Why wont it work with iso (or folder) for sure?
ISO won't work with Remote Potato. An ISO requires user input and has menu structure, etc. A transcoder can't stream that interface and you [ the streamer] can't send data back to the transcoder to interact with the menu.
Folder wouldn't work for this same reason. It would load a menu.
jrwalte is offline
post #32 of 35 Old 10-03-2012, 12:56 PM
galileo2000's Avatar
Originally Posted by jrwalte View Post
I was not referring to streaming within my home network. I have the same setup as you within my home at every TV. I stream over the internet with Remote Potato. You can't do that with ISO.
I have a hardwired network in my house, and can access any of my machines from any other machine with GB Ethernet speeds.
I use either my Sony tablet S or my laptop w/build-in IR blaster instead of a mouse/keyboard, which lets me fully control my HTPCs and A/V equipment.
Good time to buy computers and computer parts: NEVER
galileo2000 is offline
post #33 of 35 Old 10-03-2012, 01:51 PM
jrwalte's Avatar
No. Universal remote with only directional arrows and OK is just more streamlined and layman approved smile.gif
jrwalte is offline
post #34 of 35 Old 10-03-2012, 02:27 PM
Look, I don't care about layman approval and universal remote, been there, done that. My current modus operandi serves me much better biggrin.gif
post #35 of 35 Old 10-09-2012, 08:53 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
You're assuming that the Echo will be transcoding rather than just playing the files directly. Have they said that?
Carty Custom Builders, LLC
ncarty97 is offline
Reply Home Theater Computers
