Question for the guys with HUGE Blu Ray collections - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 09-26-2012, 01:19 PM - Thread Starter
Darrin's Avatar
How do you typically backup your Blu Rays? I prefer NOT doing a 1:1 copy as I could care less about extras and use Clown BD. I'm just wondering for the guys that do a TON of backing up, what are some of the best methods?
Darrin is offline
post #2 of 35 Old 09-26-2012, 01:23 PM
danbez's Avatar
Quoted: 39 Post(s)
Use ClownBD to rip only the main movie, the HD sound track and any subtitles you want (with no quality drop). Everything else is gone.
The output can be just a regular Blu-Ray folder structure, ISO, MKV, etc.
http://forum.slysoft.com/showthread.php?t=25818
danbez is offline
post #3 of 35 Old 09-26-2012, 01:25 PM - Thread Starter
Darrin's Avatar
That's pretty much what I use atm. I'm just wondering if there is more of a "streamlined" approach as it does get quite time consuming.
Darrin is offline
post #4 of 35 Old 09-26-2012, 02:17 PM
ZenerDiode's Avatar
I'd love to find out as well. I currently rip to ISO, since that's the most streamlined process I could find, but it just takes up too much room. Hard drives are cheap, but I can't stand the waste.
ZenerDiode is offline
post #5 of 35 Old 09-26-2012, 02:24 PM
jrfendrick's Avatar
I don't have a huge collection (only around 20 right now), but I use AnyDVD to rip, then BD Rebuilder to create a movie-only MKV. Codecs added to allow playback in Windows Media Center. Most movies shrink down to a very reasonable size - 4 to 12 GBs, with very little noticeable loss of video quality. Nine times out of ten, if I want to watch a movie, I leave the BluRay in the case and watch the MKV on my HTPC.
You can also use BD Rebuilder to shrink a dual-layer BluRay disc to fit on a single-layer BD-R, if you prefer a physical backup.
1:1 copies, such as ripping with AnyDVD or MakeMKV, will take only as long as it takes to rip the disk with your drive. Anything that is NOT a 1:1 copy will take time for re-encoding - depending on quality level desired, it may take about twice to three times the length of the movie being backed up to complete the backup. At least, that's how long it takes on my six-core AMD Phenom II 1090T.
jrfendrick is offline
post #6 of 35 Old 09-26-2012, 05:46 PM
mcturkey's Avatar
Liked: 43
MakeMKV will rip the movie straight to an MKV with no quality loss. Handbrake can be used to take that MKV down to a smaller size, but there will be a quality difference if you're OCD about that.
mcturkey is offline
post #7 of 35 Old 09-26-2012, 06:15 PM
Tony_Montana's Avatar
Quoted: 45 Post(s)
I keep only the largest .m2ts file.
That means , Uncompressed video stream, HD audio & subtitles only.
Cons
- No extras
- much more space than x264
Pros
- best Video & audio quality
- Saving ripping time
- Speed, no bd menu, intro etc. just the main movie.
- no need of extra software for mounting .ISOs
- not installing extra filters & programs (i.e. avisynth , ffdshow , haali) for encoding to x264.
Tony_Montana is offline
post #8 of 35 Old 09-27-2012, 05:02 AM
captain_video's Avatar
Quoted: 529 Post(s)
Liked: 341
+1 for MakeMKV. I used to use AnyDVD HD for ripping and then stripped out the extras with Clown_BD. Problem was, iso playback on PCs from my server was sporatic at best. I tried MakeMKV with XBMC and it solved all of my playback problems. MakeMKV allows you to select only the audio and video tracks you want to keep with 1:1 quality. It also works great for ripping discs of TV shows with multiple episodes as it rips each one to a separate mkv file. I liked it well enough to convert my entire collection of over 900 DVD folders and Blu-Ray iso's to mkv's. Mkv format is also more device-friendly than iso's if you plan on using any portable devices or media players.
captain_video is offline
post #9 of 35 Old 09-27-2012, 07:02 AM
rbrinson's Avatar
I also use MakeMKV for storing my DVDs and Blu-Rays on my media server. As posted earlier, the process takes only as long as the drives ability to read the disc and how much of the data you are wanting to copy. It is a time consuming process, as I'm still in the process of ripping our physical discs (working on it off and on as I get a chance for the past few weeks), but it is nice to be able to pull up the movie with cover art and backdrops within MediaBrowser. Also, no more hunting for the physical disc when the kids want to watch a movie is a plus.
NVIDIA Shield Android TV - 16GB Model
Kodi with NextPVR PVR Add-on for Live OTA TV and Recorded TV
Plex for Movie Library on FreeNAS
Windows 10 & NextPVR - Manages Live OTA TV and Recording Schedules
Schedules Direct for Electronic Programming Guide
rbrinson is offline
post #10 of 35 Old 09-27-2012, 07:04 AM
jrwalte's Avatar
I use BluRip to create MKV from my choice of selected video/audio/subtitle streams.
jrwalte is offline
post #11 of 35 Old 09-27-2012, 07:22 AM
mslide's Avatar
I use eac3to to rip out the main video and HD audio tracks along with chapters. Then I use mkvmerge to merge them into an MKV file. It's more of a manual process than perhaps makemkv or clownbd but I'm used to it and doesn't really take me any longer.
mslide is offline
post #12 of 35 Old 09-27-2012, 07:33 AM
nathanddrews's Avatar
Quoted: 420 Post(s)
Liked: 355
Another vote for MakeMKV. I always take the main movie and the lossless audio track plus any relevant dubs or subs. XBMC for playback from the server.
nathanddrews is offline
post #13 of 35 Old 09-27-2012, 10:17 AM
WylieKylie's Avatar
OP, you are thinking about this the wrong way. If you save the movie onto a hard drive that copy becomes your working copy, and the disk itself becomes your backup.
And add another vote for Make MKV. I rip the main title only, except in the case of kids movies that have shorts on them (usually Pixar, Dreamworks). I have a separate library on Media Browser just for those shorts.
WylieKylie is offline
post #14 of 35 Old 09-27-2012, 01:46 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
This. (assuming you aren't transcoding or otherwise altering the data in a time/labor expensive manner AND assuming these are are rips from discs you own)
The problem is not that you don't have a backup; it's that your recovery process is slow and laborious. You'll probably get a better bang for the buck by focusing on improving that process instead of making (and maintaining!) a whole new backup system. One of the huge benefits of this method is that every time you add new content to your library, you are simultaneously testing and retraining yourself on your disaster recovery process. The value of this shouldn't be understated. One of the things I've learned working as a storage admin: when untrained people are thrown into a DR scenario, they are just as likely to worsen the situation as improve it.
Things to look at: streamlining your ripping, learning the batch processing features of your ripping software, upgrading your ripping software, building a multi-drive ripping box, training a kid and paying them. or just outsourcing your ripping entirely.
Things to avoid: single points of failure that could wipe out your whole working set. Your worst case scenario is having to rerip everything at once. Having to rerip a small fraction is far more bearable, especially if you also add new content on a regular basis.
If you are doing heavy transcoding or pulling from sources without physical media, then you'll want to look at a different backup solution.
EricN is offline
post #15 of 35 Old 09-28-2012, 01:01 PM
jrwalte's Avatar
You'd probably like Blurip. I used to do the same as you. All Blurip is, is a gui batch scripter that uses the other programs, such as eac3to, mkvmerge, etc. You can break it down to do only certain parts of the process (only demux or only remux).
jrwalte is offline
post #16 of 35 Old 09-29-2012, 11:45 AM
xfett's Avatar
+1 for MakeMKV and Handbrake
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #17 of 35 Old 09-29-2012, 05:02 PM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Have about 100 br and hddvd, 300 dvd. I rip everything to file format and store on my whs. Physical discs go into storage, flexraid on the whs for parity redundancy
Carty Custom Builders, LLC
ncarty97 is offline
post #18 of 35 Old 09-30-2012, 04:42 PM - Thread Starter
Darrin's Avatar
Thanks for the feedback. It sounds like I'll have to give makemkv a shot for sure!!
Darrin is offline
post #19 of 35 Old 09-30-2012, 05:03 PM
Jackal55's Avatar
I've used MakeMKV for a few of my blu ray movies and DVDFab for my DVDs. Once I build a server I would like to keep the formats as simple as possible so I might just rip everything to .mkv format.
Jackal55 is offline
post #20 of 35 Old 10-01-2012, 05:16 AM
galileo2000's Avatar
I am a minority here.
I rip disks w/AnyDVDHD, then make .iso files.
I double-click on .iso file, it gets loaded and PowerDVD starts.
I could probably save some HDD space by using MakeMKV, but I don't want to. at most I'll get something like 300GB.
Good time to buy computers and computer parts: NEVER
galileo2000 is offline
post #21 of 35 Old 10-01-2012, 08:48 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
I used to convert my DVD's to DivX to save space back in the day, but I had so many that ended up with the audio off, that I just got fed up and bought a bunch of hard drives. Much easier and much happier now!
ncarty97 is offline
post #22 of 35 Old 10-01-2012, 09:41 AM
ToddUGA's Avatar
Quoted: 39 Post(s)
Liked: 36
ToddUGA is online now
post #23 of 35 Old 10-01-2012, 10:22 AM
Artslinger's Avatar
I select the biggest m2ts file and use tsmuxer to rip only the video and one HD audio track.
Artslinger is offline
post #24 of 35 Old 10-01-2012, 12:09 PM
jrwalte's Avatar
I convert to MKV for compatibility and WAF. You can't internet stream ISO but you can MKV. And hopefully when the Ceton Echo 7MC extender is released this year, it will work with bluray quality MKVs. It will not work with ISO for sure. MKV also has greater WAF in my case. Clicking on an ISO in Media Browser to get the 'video error' message to then several seconds later be prompted to 'play disc' confuses her. Sometimes she backs out before the 'play disc' can appear and then it never does, even though the disc is now mounted and ready to be played if she went to TMT5.
jrwalte is offline
post #25 of 35 Old 10-01-2012, 08:56 PM
Not my problem, buddy.
My wife has her own entertainment center in the kitchen, and she watches there whatever she wants to.
If we are watching a movie together, double-click on the .iso file is all it takes.biggrin.gif
And yes, streaming is cool. However, I do have a dedicated HTPCs connected to the all of my screens. With my hardwired network, playing a movie from the remote HTPC or shared HDD thru the router is a breeze.
post #26 of 35 Old 10-01-2012, 09:29 PM
NewOrlnsDukie's Avatar
Liked: 29
I have 800 lossless BR's (movies and TV shows) and 50 HD DVD's, and my overall collection is 1500 movies and 60 complete TV series. No iso's. All mkv's and m2ts.
I use:
1) AnyDVD HD and Clown BD for HD DVD's -- this allows me to rip the films and retain HD audio tracks without the ever-annoying framerate bug on HD DVD's with MakeMKV
2) MakeMKV (keeping HD Audio tracks) for everything else.
I have everything on my server, with Plex for my OS X HTPC clients, and MediaBrowser for my Windows clients.
NewOrlnsDukie is offline
post #27 of 35 Old 10-02-2012, 05:13 AM - Thread Starter
Darrin's Avatar
I use:
Nice! I use Clown for various Blu Rays and all my HD-DVD's. I just started playing with MakeMKV and all I could say is.....WOW!! How the heck did I miss this app!!! I've done several DVD's (folder structure) and a few Blu Rays and it works VERY nicely!! Thanks for the tip on MakeMKV and HD-DVD. Nice to find out sooner then later:)
Darrin is offline
post #28 of 35 Old 10-02-2012, 06:59 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
This.
Except I just keep the MKV that makemkv makes and don't bother to handbrake it. I don't mind the 25-30GB size as I like the original quality at 1080p and full audio. Yes. $129 for a 3TB drive.
Mfusick is offline
post #29 of 35 Old 10-02-2012, 10:53 AM
jrwalte's Avatar
I was not referring to streaming within my home network. I have the same setup as you within my home at every TV. I stream over the internet with Remote Potato. You can't do that with ISO.
jrwalte is offline
post #30 of 35 Old 10-02-2012, 11:02 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Why wont it work with iso (or folder) for sure?
ncarty97 is offline
Reply Home Theater Computers
