Mediamaster help needed. How do I get it to recognize "NIP TUCK as tv show with seasons ???? Or is there a better program for TV shows? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-30-2012, 04:11 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I am pretty solid with Mediamaster and use it to update my library. I find it works great on movies.
If it can't find it - I have it set to ask me. I just enter in the IMDB movie ID number and boom. Done. Perfect every time.
For TV shows- It does not seems to have this feature.
For some reason I can't get it to recognize nip tuck series. I tried a few different main folder names.
If I enter the IMDB number it think's it's a movie. It names the folder funny, and does not organize the metadata for seasons correctly - or fetch the mediabrowser banners and stuff.
Anyone have advice ?????
Mfusick is offline
post #2 of 13 Old 09-30-2012, 05:22 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Originally Posted by assassin View Post
Nip/Tuck
So now what ??
I tried NIP TUCK
NIP-TUCK
NIPTUCK
I am confused what to do.
Entering the IMDB number does not work well on TV shows.
Mfusick is offline
post #3 of 13 Old 09-30-2012, 05:22 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Originally Posted by Mfusick View Post
But that does not tell Mediamaster what it is... so it fetches properly.
I don't need to rename it. I want Mediamaster to fetch the coverart metadata and backdrops... folder icons and such.
OK I tried it and it came out as "NIP" because windows declined the " / " for a folder name.
Mfusick is offline
post #4 of 13 Old 10-01-2012, 02:00 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Anyone know how to convert a movie to a TV show ????
Mfusick is offline
post #5 of 13 Old 10-01-2012, 02:00 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Or is there an alternative to mediamaster I should consider>?
Mfusick is offline
post #6 of 13 Old 10-01-2012, 02:16 PM
steelman1991's Avatar
Quoted: 221 Post(s)
Liked: 118
Have you tried 'Nip-Tuck' as an alternative - don't use it but might work.
steelman1991 is offline
post #7 of 13 Old 10-01-2012, 02:17 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I tried :
NIP TUCK
NIPTUCK
NIP-TUCK
none worked.
Mfusick is offline
post #8 of 13 Old 10-01-2012, 02:18 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Putting in the IMDB number turns it into a movie and it does not show properly ... as such.
I want to keep it as a TV SHOW.
Mfusick is offline
post #9 of 13 Old 10-01-2012, 03:48 PM
Quoted: 221 Post(s)
Liked: 118
Sorry should have read a little further back - why not ask on the MCM forums, seems a more likely place to get more interest than here.
post #10 of 13 Old 10-01-2012, 04:06 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
I had the same problem with not only Nip/Tuck but many other series so I just manually enter each one into media master now and then I can manipulate the meta-data any way I want. I don't like the description for many of my movies and TV shows because they seem to describe every minute of the program instead of just giving the plot line.
Dropkick Murphy is offline
post #11 of 13 Old 10-02-2012, 07:57 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
So you saying you manually fetched every episide and edited it?
I have all 6 seasons. That seems like a lot of work for something medimaster normally would do automatically and to my satisfaction.
Or did I not understand?
Mfusick is offline
post #12 of 13 Old 10-02-2012, 04:15 PM
Quoted: 71 Post(s)
Liked: 89
I know it sounds like a lot of work but the Info from MCM - IMDB is often incomplete and/or inaccurate. My way is not for everyone but it works for me and I don't mind a little extra effort to get the result I want.
post #13 of 13 Old 10-12-2012, 10:17 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I just used the RageTV ID and it worked great.
Mfusick is offline
Reply Home Theater Computers
