Core i3 interlacing performance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-05-2012, 03:25 AM - Thread Starter
sfuchs77's Avatar
Hi there,
I've already read serveral threads here and need some help with the setup for my new HTPC:
Mainly I'am planning to use it for Live TV streams of 1080i TS from my Dreambox. At the moment this job is done by an old iMac from 2008 using XBMC.
VDADecode does not work in this situation because the streams are interlaced, so the CPU has to do all the job and this is too much for that machine
Can somebody state something about the CPU load of an Core i3 when decoding 1080i streams without DXVA? I want to build a SFF HTPC without a discrete GPU so for me it is quite important that the wokload of the CPU is as low as possible.
I know that the decoding of 1080p material will hardly stress that CPU
Regards
Stephan
sfuchs77 is offline
post #2 of 2 Old 10-05-2012, 04:11 PM
sneals2000's Avatar
Quoted: 240 Post(s)
Liked: 127
Originally Posted by sfuchs77 View Post
Hi there,
Regards
Stephan
Why are you avoiding DXVA ? The HD 3000 and HD 4000 on-die Intel GPUs will de-interlace in DXVA. I have a Windows Media Centre based on a Sandy Bridge Pentium (less powerful than an i3) and it's de-interlacing 576/50i MPEG2 and 1080/50i H264 DVB-S/S2 streams - both from a Dreambox and an internal card - with no major problems. I wouldn't describe it as Vector Adaptive quality - but it's certainly no worse than the internal de-interlacers in some set top boxes.
sneals2000 is offline
Reply Home Theater Computers
