Did I choose a good motherboard? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-05-2012, 09:20 AM - Thread Starter
Dubro's Avatar
Just getting into HTPC and I'm thinking I might have screwed up already....
I ordered and they shipped this board:
Gigabyte A75M-UD2H AMD Socket FM1 for AMD Llano CPU, HDMI, Dual Graphic Micro ATX Motherboard
http://www.amazon.com/Gigabyte-A75M-UD2H-Socket-Graphic-Motherboard/dp/B0057TG6AW
Was that a good choice?
Dubro is offline
post #2 of 6 Old 10-05-2012, 10:03 AM
ljo000's Avatar
If you're combining this mobo with an Intel i3 then yes you did screw up. smile.gif If not, then you need to provide more info on what you are trying to accomplish and what other parts you've bought.
ljo000 is offline
post #3 of 6 Old 10-05-2012, 10:05 AM
H8nXTC's Avatar
The new FM2 boards and CPU's just came out. Most see Intel a better choice. If you do gaming, the new AMD might be a better match. If you can return it, I would and do a little more research, but a FM1 will still work.
H8nXTC is offline
post #4 of 6 Old 10-05-2012, 10:20 AM - Thread Starter
Dubro's Avatar
I'm going to use this APU:
AMD A8-3870K APU with AMD Radeon 6550 HD Graphics 3.0GHz Unlocked Socket FM1 100W Quad-Core Processor - Retail - AD3870WNGXBOX
http://www.amazon.com/AMD-A8-3870K-Graphics-Quad-Core-Processor/dp/B006J420UE/ref=pd_cp_e_0
Using:
Case: Silverstone Tek GD05B-USB3.0
SSD 128 GB drive (for O.S.)
Western digital 2 TB drive
Prime H.D. HomeRun
8 GB Ram
Power Supply SeaSonic X series SS-400FL Active PFC F3 400W ATX12V Fanless 80 PLUS GOLD Certified Modular Active PFC Power Supply
Dubro is offline
post #5 of 6 Old 10-05-2012, 10:24 AM
ljo000's Avatar
For HTPC and light gaming that setup will be fine and is actually a bit overkill.
If you want to play modern games at high resolutions and framerates, you'll need a discrete vid card so you'd be better off going intel for the CPU (much better performance per $$)
ljo000 is offline
post #6 of 6 Old 10-05-2012, 10:28 AM - Thread Starter
Dubro's Avatar
Could you suggest a good "value for money" motherboard and chip and video card for modern games and gereral htpc ues?
And what would be good for light gaming?
Dubro is offline
Reply Home Theater Computers
