MPC-HC - Color problem with EVR - AVS Forum | Home Theater Discussions And Reviews
Old 10-05-2012, 05:57 PM - Thread Starter
hypo86's Avatar
Hi,
I have this problem with MPC-HC + EVR... It's like, skin colors turn to red...
Here's the same picture using haali renderer:
I also tried with GOM Player + EVR, and it didn't have the problem, it only occurs in MPC-HC...
Any ideas?
Chris
hypo86 is offline
Old 10-06-2012, 05:51 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
Are you using EVR custom presenter?
Mrkazador is offline
Old 10-07-2012, 06:41 AM - Thread Starter
hypo86's Avatar
Yes, but it's the same with normal EVR as well...
hypo86 is offline
Old 10-07-2012, 01:02 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
While a movie is playing, right click the screen
Renderer settings- reset- reset to default renderer settings
Old 10-07-2012, 01:08 PM - Thread Starter
hypo86's Avatar
hypo86 is offline
Old 10-07-2012, 05:16 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
You can player with the renderer settings to get it how you like it.
