Simple, current HTPC guide? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 51 Old 10-10-2012, 06:37 PM - Thread Starter
lern2swim's Avatar
I'm hoping someone can either point me in the direction of a current easy to follow guide or give me some input.
I'm looking to go from having a single, all purpose PC to separating out my media and web browsing from my computing. Every time I go into "figure out what hardware components I should get" mode, however, I feel like I'm going to have an aneurism. This would be my first pc build all on my own.
What I'd like it to do:
Play ripped video files
HD
5.1
Video and audio through HDMI
Play music (using MediaMonkey)
web browsing
Possibly play emulated games (nothing past PS1 level stuff)
Have a good amount of usb inputs
Come in at a low price point.
That's all. I don't need 3D, or high end gaming graphics. I don't need it set up with a server (I just store my video and music files on external Hdds). I know, as far as HTPCs go, that's really pretty bare bones, but I'm having a hard time finding clear guidance as to how to make it happen. I'd appreciate any help I could get. Thanks.
Do you have a link to support your existence?
lern2swim is offline
post #2 of 51 Old 10-11-2012, 07:43 AM
halfordb's Avatar
I used this when setting up my system: www.assassinhtpcblog.com
he is a member here on the forums, and many of us have used his guides.
Another member on the forums who has done an extensive guide is Renethx. If you search for his posts, you will find it.
Also, if you search the forums, this topic comes up a lot, so there are going to be many in a similar spot.
Finally, you mention "current". You don't need the newest hardware to do the things you mention, so a somewhat "older" post should still work fine.
-Bill
halfordb is offline
post #3 of 51 Old 10-11-2012, 11:08 AM
ljo000's Avatar
I second the comment on Assassin's guides. Very useful. The hardware part is fairly easy IMO, its the software that will take the most time. Getting everything tweaked to perfection is a never ending process seemingly even with the guides.
If you want some example hardware, check out my build from a few weeks back:
Code:
http://www.avsforum.com/t/1426890/crazy-cheap-but-good-build-thread
$300, plays everything I've thrown at it smoothly, boots in 10 seconds flat.
ljo000 is offline
post #4 of 51 Old 10-11-2012, 12:04 PM
halfordb's Avatar
halfordb is offline
post #5 of 51 Old 10-11-2012, 12:19 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Code:
You're still tweeking? I stopped that years ago (before my teeth fell out).. Seriously I have mine set and very rarely do anything to it now becuase it just works and works the way I want it to.
Sammy2 is offline
post #6 of 51 Old 10-11-2012, 01:23 PM - Thread Starter
lern2swim's Avatar
I went through Assassin's guide, which was kind of what I was referring to when I put current, because a lot of the hardware he linked to seemed to be discontinued (of course I could go ebay hunting and probably find it) and it's when we get into the realm of "can I substitute this cpu for this one?" that things get really hazy for me.
post #7 of 51 Old 10-11-2012, 01:45 PM
Tiddles88's Avatar
Liked: 24
Pretty easy:
- Core i3 3220 or 3225 if you can find one - all the grunt you'll need for a while yet
- Gigabyte H77M-D3H - I'm using this board in two systems. Its that good. Everything you need and nothing you don't.
- 128GB Samsung 830 for Win 7 + 2TB for bulk storage
- 8GB KVR DDR3 1333MHz kit
- Silverstone GD 05 USB 3 (the newer one, the front USB 3 will connect to the internal header on the Gigabyte mobo)
- Seasonic G360
Voila!
Tiddles88 is offline
post #8 of 51 Old 10-11-2012, 02:01 PM - Thread Starter
lern2swim's Avatar
Originally Posted by Tiddles88 View Post
Pretty easy:
- Seasonic G360
Voila!
Thank you. That's exactly the type of thing I'm looking for. I love options, but in this instance they're giving me a headache.
post #9 of 51 Old 10-11-2012, 02:44 PM - Thread Starter
lern2swim's Avatar
How about this, if I go amd:
Phenom II X4 945 http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4615717&CatId=4431
AMD 880 mobo http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7109093&csid=_61
The Kingston RAM http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3683218&CatId=4534
(or should I spend a couple extra bucks and go with this http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=40739&csid=_61)
The Samsung SSD http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2318704&CatId=5300
And then what case and psu would I go with? I'm not finding much on that SIlverstone (especially which ones are the "new" ones)
post #10 of 51 Old 10-11-2012, 03:04 PM
Tiddles88's Avatar
Liked: 24
That AMD chip is much hotter and slower than the i3. Its an old inefficient architecture. I wouldn't bother. The i3 3220 is far superior.
A comparison between them (not that comprehensive but it will do):
http://www.anandtech.com/bench/Product/677?vs=80
post #11 of 51 Old 10-11-2012, 03:17 PM - Thread Starter
lern2swim's Avatar
It's also a higher price point. As is the mobo. So, is there a better cpu/mobo combo around the price point of the ones I posted?
Keep in mind, unless there's some new, really taxing video or audio file format that comes along, I don't need future proof. I just need it to do the things in my first post.
post #12 of 51 Old 10-11-2012, 03:25 PM
Tiddles88's Avatar
Liked: 24
Its higher in price because its far superior. The Phenom's are EOL and obsolete. The i3 is far from future proof. Its the best current option for your needs. The Phenom sucks more juice, needs more cooling due to its higher TDP and its architecture is old and creaky. I would not recommend it and if you poke around online you'll see its not worth buying at all. If you want a decent long lasting option you'll need to pay that bit extra.
post #13 of 51 Old 10-11-2012, 03:30 PM - Thread Starter
lern2swim's Avatar
So, it's not a matter of that chip being inferior, it's a matter of anything below the i3 price point not being good enough to do what I want it to? Okay, if that's the case, then that's entirely different. Got it.
Out of curiosity, what would AMD's closet equivalent to that i3 be?
post #14 of 51 Old 10-11-2012, 03:32 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
A6-3500.
Sammy2 is offline
post #15 of 51 Old 10-11-2012, 03:39 PM
Tiddles88's Avatar
Liked: 24
The A10 5800K is very close, within 5%. I don't know where the recommendation for the A6 comes from. This should show you that AMD's best can barely compete with a mid-range i3. For your setup, an i3 is perfect.
post #16 of 51 Old 10-11-2012, 03:45 PM - Thread Starter
lern2swim's Avatar
Yeah, I just found the A10 comparisons. It's about the same price though, so it'd be fairly pointless to go with that over the i3.
So, I guess my main nagging concern is still just whether the i3 would be overkill for what I need seeing as I have a pc already for the bulk of my computing.
post #17 of 51 Old 10-11-2012, 03:53 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
The A6-3500 can perform just fine for HTPC duties and can even handle MadVR because it has better graphics processing. It is, however, more in line with the G-620 with better graphics thatn the i3. The point being that it will perform fine in and HTPC.
Sammy2 is offline
post #18 of 51 Old 10-11-2012, 03:54 PM
Tiddles88's Avatar
Liked: 24
Then I'd get a Celeron G540 over an i3 with the rest of the parts I posted. That will still do the job, its $40 and if you need an i3 down the road, you can just drop it in.
post #19 of 51 Old 10-11-2012, 04:00 PM - Thread Starter
lern2swim's Avatar
Okay. I'll do some research and figure out which would be better for me.
And hopefully I'll be able to find that case.
post #20 of 51 Old 10-11-2012, 04:04 PM - Thread Starter
lern2swim's Avatar
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163174&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-NA-_-NA
Is this the one you're talking about?
post #21 of 51 Old 10-11-2012, 04:19 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That link is for a case.
Sammy2 is offline
post #22 of 51 Old 10-11-2012, 04:22 PM - Thread Starter
lern2swim's Avatar
Sorry, I should have inserted that into the previous post. I'm looking for the case that Tiddles recommended but can't find it. That link I just posted refers to the case as the follow up to the one he recommended as far as I can tell.
post #23 of 51 Old 10-11-2012, 05:08 PM
ljo000's Avatar
If you're near a microcenter, the G630 is $50 and at that price is absolutely the best HTPC buy in price/performance terms. If you want to add 3D capability, you could get one of those $15 vid cards that pops up on newegg every now and then. For me this wasn't a requirement though.
ljo000 is offline
post #24 of 51 Old 10-11-2012, 05:12 PM - Thread Starter
lern2swim's Avatar
I am, sadly, nowhere near a microcenter. I'm about 8 hours away from the nearest one, as far as I can tell.
The price on the g630 is still not too bad on Tigerdirect though. I assume I could use that in place of the i3 in the mobo Tiddles recommended as well the same as I could do with the Celeron G540, right?
post #25 of 51 Old 10-11-2012, 05:42 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Socket 1155.
Sammy2 is offline
post #26 of 51 Old 10-11-2012, 05:45 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1072436
As an example. You don't want the MoBo in this combo but yes, Socket 1155 in the other board is what you want.
Sammy2 is offline
post #27 of 51 Old 10-11-2012, 05:48 PM - Thread Starter
lern2swim's Avatar
The mobo in that combo doesn't have hdmi.
I think I'm just going to spend the extra cash and get the i3. So, I just need to figure out a case and psu combination.
post #28 of 51 Old 10-11-2012, 05:51 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
I will try to (again) update my hardware guide at my blog soon. Sometimes "discontinued" at newegg just means it's out of stock.
assassin is online now
post #29 of 51 Old 10-11-2012, 05:56 PM - Thread Starter
lern2swim's Avatar
I know. It was just the fact that every cpu suggestion link I checked said discontinued that led me to ask. I didn't mean it as a knock against you. Your guide IS awesome and a good jumpstart (especially for someone that's a bit better at pc hardware shopping than I am), and I understand that it's really damn hard to stay absolutely up to date with tech stuff.
post #30 of 51 Old 10-11-2012, 06:27 PM
wco81's Avatar
Quoted: 1188 Post(s)
Liked: 412
Pretty easy:
- Seasonic G360
Voila!
Is that a good setup for a WMC DVR? If I get the HD HomeRun with CableCard or one of the Ceton CableCard tuners? Will it "just work" with a Ceton Echo media extender?
wco81 is offline
Reply Home Theater Computers
