Small quiet htpc for bedroom - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2012, 01:00 PM - Thread Starter
cburbs's Avatar
Quoted: 94 Post(s)
I am looking to move the wdtv live plus to the kids room and would like to get a small htpc to replace it....what I am looking for it to do:
Stream Netflix, MLS Live Soccer, ESPN3
WMC – No live tv but use shared folder from main HTPC for tv show playback
MediaBrowser\XMBC for movies from network
Small, Quiet, Fanless if possible as this is replacing my WD TV Live Plus
Options I have seen:
FitPC3 basic barebone
Foxconn is coming out with a few fanless ones.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
Old 10-12-2012, 01:34 PM
Tiddles88's Avatar
Liked: 24
I built this one for $300:
http://www.avsforum.com/t/1429850/my-dirt-cheap-300-htpc-build-please-rate
It cannot be upgraded with a GPU (or anything actually with that case) but it should be fine for what you want to do. Even though I'm using the stock heatsink you can't hear it unless you put your ear to the case.
Tiddles88 is offline
Old 10-12-2012, 03:27 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
There's a good one if you Google "e-i5 intel barebones".
It's what I have with the G620 for my bedroom HTPC and it's very quiet. I used it to watch 1080p MKVs over the network, live HD TV, Netflix, Xfinity, Hulu, ABC.com, etc. and listen to music from the server and streaming.
StardogChampion is offline
Old 10-12-2012, 04:53 PM - Thread Starter
cburbs's Avatar
Quoted: 94 Post(s)
Your e-i5 series was another one on my list but not quite as small as some of the others.
cburbs is offline
Old 10-18-2012, 07:37 PM - Thread Starter
cburbs's Avatar
Quoted: 94 Post(s)
This isn't bad - http://www.newegg.com/Product/Product.aspx?Item=N82E16856119072&name=Mini-Booksize-Barebone-Systems
Add some memory and your under $200.
cburbs is offline
Old 11-29-2012, 08:16 PM - Thread Starter
cburbs's Avatar
Quoted: 94 Post(s)
Looks like there are some more options for small pcs - http://www.htpc-reviews.com/complete-systems. Just not sure how queit some of these will be.
cburbs is offline
Old 11-29-2012, 08:28 PM
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
That 1.6 GHz AMD E-350 is the same one I have on a Gigabyte board I use and I'm having streaming troubles with 1080p from my Windows Home Server. It's possible to overclock it to maybe 1.8 but heat and noise would then become an issue.
That said, it does work well for just about every other use I have for it including music, Live & recorded TV, etc. A bit noisy though.
ajkrishock is offline
Old 11-29-2012, 08:33 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I don't recommend zacate or atom at all. Much much better options out there for about the same cost.
assassin is online now
Old 11-29-2012, 08:38 PM
Quoted: 93 Post(s)
Liked: 160
The Q190 looks interesting -- finally some small PCs that are NOT Zacate or Atom but Celeron mobile!
Old 11-29-2012, 10:38 PM
Quoted: 93 Post(s)
Liked: 160
The E-i3 is available now. It's 15mm shorter than the E-i5 at 60mm.
(also available in black)
And this one too (S197-H80):
197mm x 197mm x 80mm
Old 11-30-2012, 07:07 AM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
If you do go for the Foxconn, spend a few more $ and get this one, you will get good 1080 playback without need to overclock. Noise is pretty low, but you would probably want to keep it in sleep when not using.
DanPackMan is online now
