Dang, 5.1 audio reset to 2.0... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-15-2012, 03:07 AM - Thread Starter
Favelle's Avatar
Everytime I change my HDMI input on my receiver or turn off my HTPC or if it goes into sleep mode, it resets the audio to 2.0. Damn, is there a way to make my audio config stick?
In terms of LFE, size does matter!
Favelle is offline
post #2 of 7 Old 10-15-2012, 10:05 AM
rbrinson's Avatar
Is this possibly an EDID issue? In my setup, my HTPC and Blu-Ray player are connected via HDMI to my Sony AVR. The AVR then has one HDMI out that connects to the HDTV. I had an issue where I would lose the audio device on my HTPC whenever the HTPC would go into sleep mode or if I put the AVR into standby mode. Of course, rebooting the HTPC would resolve the problem, as would disconnecting and reconnecting the HDMI cable between the HTPC and the AVR. I also used a little piece of software called HDMI On which simply forces the HTPC and AVR to go through the HDMI handshake process. However, none of these options are wife or kid friendly. So, I ended up purchasing a HDMI Detective Plus. You go through a simple process to program the HDMI Detective with the EDID information of your AV sink. It then stands in place of the AV sink and causes the HTPC to think that the device is always connected. I have also heard from another user on these forums that an HDMI repeater worked for him. However, I have not used that device and cannot speak from experience.
NVIDIA Shield Android TV - 16GB Model
Kodi with NextPVR PVR Add-on for Live OTA TV and Recorded TV
Plex for Movie Library on FreeNAS
Windows 10 & NextPVR - Manages Live OTA TV and Recording Schedules
Schedules Direct for Electronic Programming Guide
rbrinson is offline
post #3 of 7 Old 10-15-2012, 03:10 PM - Thread Starter
Favelle's Avatar
Dang, that seems like what's happening to me. Didn't happen with my old HTPC (Athlon x3 with a Radeon 6450), but this one (Intel G870 with a Radeon 7770) will not hold the speaker configuration. All I have to do it right click the speaker icon and change it to 5.1 and it fixes it, no reboot or unplugging anything, but, still a hassle. Doesn't affect me for movies or shows as those are all bitstreamed through XBMC, but I am gaming on this machine and I have to change it to 5.1 whenever I light up a game. frown.gif
Favelle is offline
post #4 of 7 Old 10-16-2012, 03:27 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
Do you have the HDMI Audio set as your DEFAULT audio? How about the HDMI display as well should be set as your DEFAULT. When you shutoff the PC, or stabdby, does the PC have speakers connected or are your only audio devices digital? It could be a setting in the config that is set to speakers causing the PC to go to speakers when the TV or AVR is switched off.
Andrew Hornfeck is offline
post #5 of 7 Old 10-18-2012, 03:33 AM - Thread Starter
Favelle's Avatar
Yep, HDMI audio is default. HDMI display is the ONLY display and is also default. No speakers connected, everything is run through my receiver to my projector.
Favelle is offline
post #6 of 7 Old 10-19-2012, 03:56 PM
Quoted: 30 Post(s)
I suspect the video is also on-board -- have you disabled the on-board video in BIOS to allow the Radeon to remain as the sole device?
post #7 of 7 Old 11-30-2012, 02:53 AM - Thread Starter
Favelle's Avatar
Thanks man, I'll try that tonight to see if that works.
Favelle is offline
Reply Home Theater Computers
