New/Upgraded HTPC Build i3 3225 - Question and problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-15-2012, 04:07 PM - Thread Starter
mogulman1's Avatar
Quoted: 12 Post(s)
I ended up going to Microcenter yesterday and picking up an Intel i3-3225, a Gigabyte GA-Z77M-D3H-MVP mATX motherboard, 8GB (2 stick) Corsair XMS DDR3 RAM, and a Seasonic 400w fanless PS.
I took out the guts of my old HTPC in my Silverstone GD05b. Same HDs/DVD and tuner cards. Using the built-in HDMI on the motherboard. Windows 7 ultimate 64 bit. Loaded all the newest bios and drivers.
Seems to be working almost great......
One problem:
I noticed that if I have any amount of static on my finger and touch the Silverstone case, the Display on my TV starts going wacky (Whole screen starts cycling through RGBW, or turns black). This happens while in BIOS or in the OS. Not that I should be trying to shock the case, but I can see someone dusting or touching it while loading a DVD. Anyone had this happen before? If I was going to guess I would say this is a Power Supply or MB issue. Probably more motherboard, but just wanted to see what people thought. I could try replacing the Seasonic with my old Silverstone 400w PS I guess and see. oh.. I also have one of the case fans wired to 12v/5v=7v so it will run slower. Maybe this could be causing something? Also, this didn't happen with my old MB, PS...same case..
One question:
For the HD4000 video, is there a recommended setting for using it with WMC? In Bios I have it using 1024MB ram, and Max on the other setting (can't remember the setting). I turned off dynamic contrast. I left skin tone and film detection on.
A couple of things I noticed so far.. I am bitstreaming audio. I noticed that in Windows a lot of the system sounds don't play through the HDMI. This used to happen on my ATI 5570, but seems to be more prevalent on the HD4000. I'm assuming ATI had something that kept the audio to my stereo receiver open for a longer period even when it wasn't being used? or something?
Also, when watching programs, the video seems slightly more fuzzy on the HD4000. Could be my imagination though, since I was just sitting a lot closer when I was configuring the HTPC when using the HD4000.
Any help would be greatly appreciated.
mogulman1 is offline
post #2 of 6 Old 10-18-2012, 06:05 PM - Thread Starter
mogulman1's Avatar
Quoted: 12 Post(s)
Did some testing today with different power supplies, everything unplugged from the MB. Still the static would kill the display.
I ended up switching out the Gigabyte MB with an ASUS P8H77-M. No issue with touching the case now.
Guess I should have bought ASUS or Intel to start.
post #3 of 6 Old 10-18-2012, 06:24 PM
Toys7505's Avatar
Quoted: 71 Post(s)
Liked: 27
Your static problem maybe from the motherboard and the standoffs used to attach to the case causing a grounding issue.
Did you use nylon washers as an insulator between the motherboard and standoffs? They are inexpensive to get at Depot or Lowes - worth a try........
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #4 of 6 Old 10-18-2012, 08:04 PM - Thread Starter
mogulman1's Avatar
Quoted: 12 Post(s)
I didn't use insulators. I didn't think people used insulators when building pcs anymore. Most of the MBs ground through the screws/case.
post #5 of 6 Old 10-18-2012, 08:16 PM
flocko's Avatar
You are correct . Insulators have not been used in "forever" . However , that does not mean that Toys is wrong in his suggestion . We have all seen stranger things, I am sure I have . Grounding issues are a real brain teaser as locating them is rarely easy .
I would totally remove the motherboard from the case and place it on a cardboard surface ( like the MB box) and test the mother board in question. This will eliminate the motherboard if the issue goes away OR incriminate the case in combination with this particular board .
It sure would not hurt either to purchase $1.00 worth of nylon washers( keep them thin as possible) to fix the issue if it is determined that the case / Gigabyte MB combo is the problem .
flocko is offline
post #6 of 6 Old 10-19-2012, 08:27 AM - Thread Starter
mogulman1's Avatar
Quoted: 12 Post(s)
I already replaced the MB with an ASUS anyway. This solved the problem. So it was either a defective MB, or just Gigabyte in general being less tolerant to static.
Reply Home Theater Computers
