Move Netflix button in WMC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-26-2012, 07:58 AM - Thread Starter
lockdown571's Avatar
Quoted: 71 Post(s)
Liked: 95
Has anyone been able to successfully move the Netflix button to another strip in WMC? I tried Media Center Studio, but I can't actually find the Netflix button anywhere even though it's there in WMC.
lockdown571 is offline
post #2 of 7 Old 10-26-2012, 08:22 AM - Thread Starter
Quoted: 71 Post(s)
Liked: 95
Well, it appears Media Center Studio isn't working at all. No changes I make are reflected in WMC. I tried Assassin's workaround here, but no dice.
post #3 of 7 Old 10-26-2012, 02:20 PM
tcs2tx's Avatar
Are you also running MCSfix? If you do not, the Media Center Studio changes are often not implemented.
tcs2tx is offline
post #4 of 7 Old 10-26-2012, 02:36 PM - Thread Starter
Quoted: 71 Post(s)
Liked: 95
If you mean the workaround described in Assassin's poster with the zipped folder and whatnot, then yes.
post #5 of 7 Old 10-26-2012, 02:54 PM - Thread Starter
Quoted: 71 Post(s)
Liked: 95
MCE Reset Toolbox also does not work for me. My WMC seems particularly stubborn frown.gif
post #6 of 7 Old 10-26-2012, 03:00 PM
tcs2tx's Avatar
No. Read that thread in its entirety (less than 2 pages). You will see the following:
"As it stands, you still need to apply the McsFix to get full functionality from Media Center Studio."
Your solution according to the thread and my experience is 1) use Assassins folder and 2) run MCSfix.
tcs2tx is offline
post #7 of 7 Old 10-26-2012, 03:16 PM - Thread Starter
Quoted: 71 Post(s)
Liked: 95
Thank you! Got it working now.
Reply Home Theater Computers
