Video card for htpc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 10-26-2012, 02:25 PM - Thread Starter
jefejt's Avatar
I'm looking to get a video card to update my htpc. What should I look for? How much RAM? Number of video processors? I'm not playing game but will be watching hd video.
jefejt is offline
post #2 of 17 Old 10-27-2012, 08:22 AM - Thread Starter
jefejt's Avatar
Any thoughts on these?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500237
They are both under $20 after rebate and have HDMI connections. I know nothing about RAM needed, video stream processors or what I'm looking for. Any help? I don't do gaming, just watch TV and Bluray via the HTPC.
jefejt is offline
post #3 of 17 Old 10-27-2012, 08:31 AM
Multimediashtick's Avatar
Quoted: 24 Post(s)
Liked: 42
Anything listed as VP4 or VP5 with featureset C or D ought to work.
https://en.wikipedia.org/wiki/Nvidia_PureVideo#Table_of_PureVideo_.28HD.29_GPUs
Multimediashtick is offline
post #4 of 17 Old 10-27-2012, 08:41 AM - Thread Starter
jefejt's Avatar
So, I guess they'd be good. Can anyone educate me on video processor streams? RAM needed/used? CUDA cores? So I can compare...
jefejt is offline
post #5 of 17 Old 10-27-2012, 10:38 AM
Quoted: 24 Post(s)
Liked: 42
The one GB cards work just fine. On board Ram should be 4GB IMO at a min for 3 or 4 tuner use with a dual core cpu [though the unit with the GT430 is a single core 2.8 with 2 GB ram and runs 3 tuners {two record one view} without any issue at all]. I have run the GT430 [asus] and GT520 [zotac] [GT610 is the same as a GT520]. Have looked at the 2GB versions but not seeing a need to do that and they can need a power supply level I do not have at this time. Fanless versions need additional ventalation it seems and the fins can prohibit easy install. Even the GT430 had too wide a fins and would block my only other port hence the zotac in one of my HTPC's [needed to add a giga speed nic].
post #6 of 17 Old 10-27-2012, 10:47 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
I've had very good luck with these for 1080p MKVs, live HD TV and other sources (streaming, DVD rips, etc.)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102933
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
StardogChampion is offline
post #7 of 17 Old 10-27-2012, 12:45 PM
ser_renely's Avatar
I got the silent Saphire 6450 with the rebate pretty happy with it so far. I noticed my mpeg2 video looked better with it, but I am a novice and don't really know what I am doing.tongue.gif
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
ser_renely is offline
post #8 of 17 Old 10-27-2012, 02:32 PM
Tiddles88's Avatar
Liked: 24
Don't bother with the G210's. They are decrepit and old. HD 4000 graphics are enough in the i3 3225, its as fast as a 6450. Unless you want MadVR - do you OP?
Tiddles88 is offline
post #9 of 17 Old 10-27-2012, 02:38 PM - Thread Starter
jefejt's Avatar
I just want hdmi output to my tv and I need a card to do so. If G210 are no good then what?
jefejt is offline
post #10 of 17 Old 10-27-2012, 03:27 PM
Tong Chia's Avatar
The two cards that Stardog Champion recommended are pretty good.
Here is an older article about small low end HTPC cards
http://www.anandtech.com/show/3973/nvidias-geforce-gt-430
I have the GT430 mentioned in the article it is about $50
Tong Chia is offline
post #11 of 17 Old 10-27-2012, 03:40 PM
Dave84's Avatar
Sapphire 5450 is all you'll need if there is Micro Center near you you can get one there I got mine on sale and with the mail in rebate paid 20 bucks for it. I got the low profile and silent model it runs hot so directed a small internal fan at it and it runs cool now. I like AMD cards over Nvidia they're easier to install straight forward control and not so buggy.
Dave84 is offline
post #12 of 17 Old 10-27-2012, 04:07 PM
ser_renely's Avatar
I think my 6450 was like $25 after rebate, surely a better deal than the 5450?
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #13 of 17 Old 10-27-2012, 04:48 PM - Thread Starter
jefejt's Avatar
So people recommend a 6450. What makes it better than a gt 210? I don't doubt it is I want to know why
jefejt is offline
post #14 of 17 Old 10-27-2012, 05:34 PM
ser_renely's Avatar
I don't really know why, even though I am fairly technical, I just don't know hardware well. I read a bunch of reviews and the 6450 had the best picture in htpc shootouts. I think that is the general consensus? for cards around this price range(and better cards don't really do much better if at all)
A lot of things are driver related and usually a mild war between nvidia and ATI. I bought ATI bc from what I read at the time it was better at true 24p and overall picture quality. There are benefits and drawbacks to each company. I don't know anything about the gt210, sorry. I googled 6450 htpc reviews and that got me mildly educated.
If you have decent A/V equipment and are a bit of an 'phile you definitely need a card.
I am an nvidia shareholder, but own two ATI cards....go figure.
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #15 of 17 Old 10-27-2012, 11:11 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
The 210 is much weaker than the 5450/6450, and it will not bitstream HD audio, if that is important to you.
jdcrox is offline
post #16 of 17 Old 10-28-2012, 04:16 AM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I bought this one a couple months ago for $14.99 on sale & after a $25 rebate.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127584
I was experiencing the 29/59 bug in WMC7 when watching some older SD OTA programs and an HD 6450 was supposed to fix this & it did. I just waited for one to go on sale & so far it works for me & no complaints. It does have a fan but my HTPC is hidden in the corner so I don't hear it, and I think the PSU fan is louder anyway but it's difficult to determine at this point in time.
Mike99 is offline
post #17 of 17 Old 10-28-2012, 09:48 PM
grumbledook's Avatar
I had a G210 that I used again while waiting for a lp 7750 to be released. It died so I tried used the integrated graphics on my intel sandy bridge g850 cpu. The HD1000(Think it is that, less than 2000 atleast) was faster to my surprise.
grumbledook is offline
Reply Home Theater Computers
