How to mirror my PC display to a tablet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-28-2012, 12:14 PM - Thread Starter
gaidin43's Avatar
So with the release of windows 8 and the free media center I am planning on trying it out on my HTPC. However, I am trying to figure out a way I can use a kindle fire HD or a google nexus 7 as my remote by mirroring the desktop and the metro UI to both the TV and the tablet at the same time. Does anyone know how to get this to work? If I log in remotely using Remote Desktop it locks the main display screen (the TV).
gaidin43 is offline
post #2 of 8 Old 10-28-2012, 01:29 PM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
IMO, using remote desktop as a remote is a bit of a brute force solution. There are apps for Android specifically designed to be remotes for WMC. Take a look at these two:
Ceton Companion
Media Center Control
I'm pretty sure the Ceton App is also available for the Kindle Fire.
lockdown571 is offline
post #3 of 8 Old 11-01-2012, 01:31 PM - Thread Starter
gaidin43's Avatar
Is there anyway to mirror your desktop to a tablet? While still being a me to view it on the main screen?
gaidin43 is offline
post #4 of 8 Old 11-01-2012, 01:37 PM
ljo000's Avatar
There is an app/program that does exactly what you want: Splashtop
You put the server on your PC and you then have remote desktop from your iOS, Android or WebOS tablet.
ljo000 is offline
post #5 of 8 Old 11-18-2012, 05:31 PM
Iceman1605's Avatar
Quoted: 28 Post(s)
Liked: 39
I am interested in this too. The problem with splashtop when I tied it was that it lowered the resolution on my htpc whenever I turned remote desktop on.
Iceman1605 is offline
post #6 of 8 Old 11-18-2012, 06:13 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Teamviewer will keep your main screen active while remote logging into it and putting the desktop on your tablet.
http://www.teamviewer.com/en/index.aspx
oman321 is offline
post #7 of 8 Old 11-19-2012, 12:35 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Ceton Companion
Well said
Mfusick is offline
post #8 of 8 Old 11-20-2012, 12:07 AM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
This is done by default, but there is an option to turn this off on the tablet.
fitbrit is offline
Reply Home Theater Computers
