Android tablets - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 10-30-2012, 08:17 AM - Thread Starter
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Looking into a tablet. There are a few lesser known brands, pico, cube etc. They're very cheap but are they any good?
The Cube U9GT2 has high resolution display, and probably want this for a 10" tablet. Around £150, cheaper than even the lowest capacity Nexus 7.
Is the CPU/GPU up to the job on these tablets with the newer higher resolution display? ie when opening a high resolution picture and zooming in then scrolling, swiping menus, 1080 movies, scrolling web pages etc.
fatbottom is offline
post #2 of 22 Old 10-30-2012, 08:38 AM
lockdown571's Avatar
Quoted: 37 Post(s)
Liked: 87
I think cheap no-name Android tablets are a bad, bad idea IMO. Android is such a rapidly developing platform, and these tablets just aren't going to receive regular updates like the Nexus 7. Is there a reason you don't want the Nexus 7? Do you need a 10"?
lockdown571 is offline
post #3 of 22 Old 10-30-2012, 09:23 AM
cdru's Avatar
Quoted: 20 Post(s)
Nexus 7 just dropped their prices. 16GB for $199 and 32GB for $250 (at least on this side of the pond). It has better processor, better screen (smaller, but higher resolution), better OS, and better support. It's obviously a smaller tablet, but I own both a Nexus 7 and a 16GB 10" ASUS Transformer and prefer the Nexus 7 size wise for anything that I wouldn't normally need my laptop for (programming, significant word processing/excel, photo editing, etc).
cdru is offline
post #4 of 22 Old 10-30-2012, 10:11 AM - Thread Starter
fatbottom's Avatar
Liked: 519
Google Nexus 10 will be around £400. Cube U9GT5 about £160. Cannot really justify the difference. Sure the Google will get updates but been happy with non updated samsung android phone so not really fussed
32GB Nexus 7 is £200.
cdru, a couple of new tablets have higher resolution screen. Called Retina. LOL.
http://www.cube-tablet.com/cube-u9gt5-9-7-inch-retina-screen-u9gtv5-32gb.html
100% brand new Original Cube U9GT V Android 4.1 Jelly Bean Tablet PC
Retina 9.7" IPS Capacitive Multi-touch 10 Points(2048x1536)
Rockchip 3066 Dual Core CPU
Dual Camera(Front 2.0MP,Rear 2.0MP)
Support Skype Video call and Google play store
Battery 10000mAh,Long Standby
1GB/16GB WIFI Bluetooth
I have no idea of a reputable seller though.
post #5 of 22 Old 11-02-2012, 10:05 AM
cdru's Avatar
Quoted: 20 Post(s)
Your original post mentions U9GT2 which has a 1024x768 screen. It wasn't until your later post that you changed it to the U9GT5 which has the "retina" (which is actually a trademark of Apple) display.
According to the website comments, there are manufacturing delays. So there probably isn't very many reputable sellers at the moment. Reviews from other Cube models seem to indicate that things mostly work. Sometimes. Unfortunately though it's like a lot of other cloned items that come from China. They come close, but they lack in the polish and finish that makes a product great. Sometimes it's not an issue. Sometimes it is. With previous Cube tablets, it seemed recommended to flash an alternate rom to fix some of the issue. Other issues weren't resolvable. Support was also basically non-existent. If dealing with those things is worth the savings and/or risks, then go for it. But I personally would want to pay a little more and get something better/more mainstream.
cdru is offline
post #6 of 22 Old 11-02-2012, 10:56 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Asus Transformer + Mizzuu + BSPlayer for all your video jukebox/playback needs smile.gif
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #7 of 22 Old 11-05-2012, 08:39 AM - Thread Starter
fatbottom's Avatar
Liked: 519
"which is actually a trademark of Apple"
Yes they're called Retina. They don't care about using the word Retina, because Apple can't do anything about it lol.
Got to love the Chinese attitude heh heh.
May consider next gen retina android tablet I'll let any bugs to be corrected, also with much higher resolution for these chinese tablets could be pushing CPU/GPU hardware , choppy/laggy and not fully supported in android/chipset?
post #8 of 22 Old 11-05-2012, 09:25 AM
Derek K.'s Avatar
get a nexus 7.
Derek K. is offline
post #9 of 22 Old 11-05-2012, 12:32 PM - Thread Starter
fatbottom's Avatar
Liked: 519
Only 7" and no microsd slot, or hdmi out. I may try using tablet as media streamer and remote control with squeezebox and htpc.
post #10 of 22 Old 11-05-2012, 02:57 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Another vote for the Nexus 7. I only have a handful of movies stored on it but have access to thousands more instantly wherever I have internet.
assassin is online now
post #11 of 22 Old 11-05-2012, 03:22 PM
flocko's Avatar
Nexus 10 . I knew I was not buying the 7 for a reason... unintentionally held out for the 10 biggrin.gif
USB and hdmi out , 32 gig model = sweet
flocko is offline
post #12 of 22 Old 11-05-2012, 03:26 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Agree with the Nexus 10. The extra screen size is nice if you are using it to view movies. If you are just using it as a remote to control WMC, XBMC, etc then I like the 7" personally.
7" is also a perfect size for my kids who actually use it more than I do to watch movies.
post #13 of 22 Old 11-05-2012, 03:40 PM
Dark_Slayer's Avatar
Quoted: 659 Post(s)
Liked: 434
You want a tablet with HDMI out for a media streamer? I assume this is for remote media streaming at a friends/relatives??
I've been just hauling a laptop along for this (plex for windows is free biggrin.gif)
I was thinking of a tablet that could duplicate this functionality in a smaller (easier to tote) form factor. There is too much I like about the nexus 7 to ignore it much longer (especially if the 8 GB dips below $150), and for the "Remote media streaming TV-out" scenarios, I was thinking of getting one of these and install plex for android on it Android dongle
Comes out quite a bit cheaper than a 10" tablet (although two gadgets opposed to one) setup looks pretty awkward though
Dark_Slayer is online now
post #14 of 22 Old 11-06-2012, 03:31 AM - Thread Starter
fatbottom's Avatar
Liked: 519
I've been looking at hose all in one media steamers. That MK802 looks good, but where is the IR receiver / IR receiver wire?
post #15 of 22 Old 11-06-2012, 01:30 PM
Quoted: 659 Post(s)
Liked: 434
I think both the 802 and 806 have USB ports, which may or may not work with all USB IR receivers. I'm really not sure if it would work with flirc (which I use) since the required driver is only Win/Lin/Mac compatible
The 806 has wifi, so it may be smartphone controllable
These things seem pre-beta to me, so it's definitely a "see if this works" kind of device I'd try to use until later.
Finding which android apps support the A9 Rockchip is a tough matter in it's own right
post #16 of 22 Old 11-07-2012, 05:17 AM
BobSalita's Avatar
Location: CHI, CLD, PAR, PHX, PDX, NKC, AUK, MEL, SYD, BUE, SCL
Can any Android tablets play Blu-Ray ISOs with menus? Over SMB?
Former Top 1000 Amazon reviewer bemoaning the loss of objective user reviews. Amazon, stop your complacency!
BobSalita is offline
post #17 of 22 Old 11-07-2012, 07:35 AM
Derek K.'s Avatar
bd menus on a tablet? no. even pc apps like vlc and mpc-hc can't do that.
Derek K. is offline
post #18 of 22 Old 11-07-2012, 09:39 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I don't think any of these tables can even mount an ISO. Plus, I assume you are looking at wireless which don't count on a full BR rip playing well over
Cheers,
Damian
post #19 of 22 Old 11-08-2012, 02:21 AM
BobSalita's Avatar
Yes, I'm thinking of wireless playback. I'm unsure if today's best wireless tablet/network can handle it. It would be iffy. I was trying to find an alternative to re-encoding Blu-Ray ISOs. Perhaps the answer is to re-encode on the fly.
post #20 of 22 Old 11-08-2012, 06:48 AM
Derek K.'s Avatar
it can't. today's wireless can't reliably support ota hd, never mind bd bitrates that could be up to 3x more.
Derek K. is offline
post #21 of 22 Old 11-08-2012, 08:15 AM
jimwhite's Avatar
Wireless A/N can do all of that easily, my setup does it....
Jim White
St. Petersburg, FL
jimwhite is offline
post #22 of 22 Old 11-08-2012, 08:28 AM
Derek K.'s Avatar
hd over wireless is a crapshoot. the conditions in your environment happen to align in your favor. for every one account like yours, there are many more with different results.
when it works, it is great. when it doesn't it can be very frustrating.
Derek K. is offline
Reply Home Theater Computers
