When ripping my Blu Rays to MKVs, do I need the 2.0 stream or will my HTPC use TrueHD audio ok? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-02-2012, 09:31 AM - Thread Starter
NeveSSL's Avatar
Hi all,
I'm ripping my media collection to my server and I was wondering if I needed to keep the 2.0 audio stream for stereo playback? Or is TrueHD enough and also have a stereo track in it? Does the same apply for DVDs?
Brandon
NeveSSL is offline
post #2 of 6 Old 11-02-2012, 09:43 AM
psuKinger's Avatar
Quoted: 701 Post(s)
Liked: 200
Originally Posted by NeveSSL View Post
Hi all,
Brandon
I think this primarily depends on what device(s) you're sending the video to.
If you're HTPC is hooked up to an A/V Receiver capable of handling TrueHD, and you have your HTPC audio codecs all configuered properly, I believe TrueHD will work.
If you're trying to send this to an XBox 360 Extender, I don't believe it will work no matter what HTPC codecs you have installed and no matter what kind of A/V Receiver the Xbox is connected to.
I could be wrong, but that's my understanding.
psuKinger is online now
post #3 of 6 Old 11-02-2012, 09:44 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
You don't have to keep 2.0. You can decode HD audio/DD/DTS, then downmix to stereo, for example, with LAV Audio Decoder.
renethx is offline
post #4 of 6 Old 11-02-2012, 10:16 AM - Thread Starter
NeveSSL's Avatar
Thanks for the reply, guys.
So ultimately, it may be best to keep it for devices that can't handle TrueHD, right? I'd rather not have to complicate a setup to save a little bit of space. I'll just keep it in. smile.gif
Thanks again!
Brandon
NeveSSL is offline
post #5 of 6 Old 11-02-2012, 11:59 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
Hi all,
Brandon
Are you going to be playing on a PC?
I have a Logitech Revue - it can't handle DTS, DTA-MA, or True HD. None of those will play at all. I did a few movies where I made an mkv with both the HD audio track as the main one and a 2.0 AAC track as a secondary one, but I just don't watch enough movies in the room the Revue is in to make that worth my while on every film.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #6 of 6 Old 11-02-2012, 12:56 PM - Thread Starter
NeveSSL's Avatar
As-is I'll be using a PC, but I'd like to plan for a bit of flexibility in case I use something different in the future. smile.gif So I'll just rip the HD and 2/0. Probably doesn't take up a ton of extra room, anyway. Maybe a gig per movie? I've not even checked yet. Ha!
Brandon
NeveSSL is offline
Reply Home Theater Computers
